Question about Panasonic KX-P2023 Matrix Printer
Carrige goes to extreme right and chatters. this occured just after cleaning, had worked fine before the cleaning
  • 71 Answers
Alignment is off on the slider track that the carriage moves left/right on. Power down, move the carriage to the far left. power back on and let the system calibrate. There should be a reset sequence where you hold down the menu or online button and keep it down while you turn the unit on. That will put it in a self test mode that you can cancel by powering off then back on.
Posted on Jul 26, 2009
Honda unicorn drive chain is jumping with extreme knocking sound.
Try checking the gearbox oil level and adjust the chain.
Apr 03, 2017 | 2005 Honda Unicorn
Canon pixma says; 0-2- p
carrige not work proper , u can clean emcoder or replaced carrige unit
Jan 05, 2014 | Canon PIXMA MP240 All-In-One InkJet...
It keeps reading 'carriage jam, close door then press ok ... ' it will not stop.
If you open the printer cover you should be able to see a guide bar where the print carrige runs, if you can touch it feel if it is dry, if it is very dry (it may have black residue) then you will need to wipe the bar with a tissue or rag to clean it and then with a toothpick carefully add some singer oil (Machine Oil) maby 4 -5 drops along the bar, and slowly move the print carrige over the newly oiled section this should lubricate the bar again and stop your carrige jam issues
Feb 09, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Think i need to bleed abs system on ford expoler.
Sounds like the abs master cylinder area is in need of replacement if the abs fuse is removed and stops better.
Chattering can occur in an abs system when the system senses wheel lockup on that wheel and attempts to anti lock that wheel.
Could also be a wheel speed sensor not working, properly.
Hope this helps.
Jul 11, 2010 | 1997 Honda CR-V
I get an error messege (carrige jam)
I have found that when I slide back the carriage to the left by hand and expose the bottom right hand side, there has been an accumulation of ink that is preventing a part from sliding from front to back. Inspect the bottom right hand side where the black and color cartridges normally sit. You will find a flat sliding piece directly beneath the position where the cartridges normally sit, that will not slide forward to the front of the printer and back towards the back of the printer easily because of the ink that has accumulated and is causing a drag. I used q-tip swabs and some alcohol and cleaned out the rails that the piece slides in. Use a flashlight to inspect. After cleaning it appears that it is printing normally again. Repeat the process as needed. Bob in NC
Jan 27, 2009 | HP PSC 2355 All-In-One InkJet Printer
Toner smudges along the extreme right side of the paper
If the smudges are gradually fading then it's likely just excess toner hitting the fuse drum. Try a few cleaning cycles/test prints and see if that makes it go away. If not, see if you can get a replacement toner.
Jan 05, 2009 | Brother HL 5250DN Laser Printer
Playstation 2 Version 14 Slimline
try shutting the drive on the right side but keep the left open with a finger if the lens light flashes a few times and goes off theres something wrong with the lens it may be a coil which has burnt out which has caused the whole lens to pack up hpoe it helps!!
Dec 12, 2007 | Sony PlayStation 2 (PS2) Console
Panasonic KX-P2023 Matrix Printer Logo
99 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
