Question about Motorola Mobility RAZR V3
Charging problems My v3 charges but when I turn it on it stays on for 20 seconds and when I press any key it just turns off. I thought by changing the battery to a new one it would work but apparently did no good at all. What solution does my phone has? (if any) Please help!!!!!!
  • 1 more comment
  • Anonymous Nov 23, 2007
    a problem in the charger
  • Anonymous Dec 01, 2007
    Have the same problem here
  • smanto_33 Dec 28, 2008
    my razr wont charge anymore. the empty battery icon flashes and does not charge.
  • 137 Answers
Sounds like water damage to me. The only sel i can give is if you a tecgh, try to flow the board a litle bit with hot air and put it togeather again and try. This is a yuppy trick, but in SA they sell a oil named Spark. I have done plenty of waterdamage cell with it, and it work. Yust dont spray on the screen, it will left splashes and shades. But if you realy have no more to try try that. Waterdamage to anything before you put it on , spray with spark , you wont believe.
Posted on Dec 22, 2007
    Brigadier General:
  • 7,752 Answers
You should reflash the firmware on the phone to correct the problem.
Why phone doesn't power on after charging ?
Frozen.
Does it show as charging when plugged in?
Try the next step when plugged in and/or unplugged.
Try: Hold the Volume Down button and the Power key simultaneously for about 15 seconds. After holding them down for about 20 seconds if the phone didn't power cycle then release the keys and try and turn the phone on like you normally would by briefly pressing the power button.
***If this did not work Try it using the VOLUME UP button with the same process*** this activates a "Power cycle"
Sep 19, 2014 | Sony XPERIA M2 LTE D2306 WHITE 4.8IN...
How to reset nook when it only stays on 3 seconds?i just got done charging
You can return to factory settings. Press "on" button and hold it for 5 second. Then, during boot, press "on" button and hold it for 15-20 second. Repeat this steps 7 more times (8 totally). Then just turn on and watch the restored factory firmware from hidden area.
Sep 05, 2013 | Barnes & Noble Nook Color
My ZTE Warp Sequent starts up but freezez on the boost logo?
In this case you can just try to reset the device by Firstly,hold the power key and volume down key;secondly,use vol- key and vol+key to move the cursor to wipe data/factory reset,press power key or menu key to select it;Thirdly,move cursor to yes,delete all data,then press power key to select it.
If the fault still happens, please contact the manufacture to upgrade software, as generally upgrading software can solve such problems.
Mar 04, 2013 | ZTE Warp
TracFone is charged, but says it is not charged and will not turn on.
Hello':":":":"
PHONE CHARGING:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
2:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 20, 2013 | LG Cell Phones
Razr V3, charging the battery
take it to motorola service center
May 25, 2008 | Motorola Mobility RAZR V3
Keeps shutting down.
The solution is found! There's no need to format your HDD
So.
- Unplug the battery;
- Press and hold the reset button for 20-25 sec;
- Put the battery back to it's place;
- Charge your device (when you plug the cable in, it turns on (note that a blinking lightning icon appears on the charging indicator), then it turns off with it's "shutting down" message, dont pay attention on this, just let it charge for about 10-15 minutes (note that the CHG bulb won't be lit));
- Turn on your device. The CHG bulb is lit, Archos doesn't shut down
- Enjoy
Jan 08, 2008 | Archos 504 500870 Digital Media Player
Phone won't turn on
You may need a new battery. Also, hold the power button in for at least 10 seconds before letting go. The RAZR has a bad habit of not completely turning on unless you hold it in long enough.
Nov 30, 2007 | Motorola Mobility RAZR V3
Won't turn on after assembly
dear first check the the power volts are comming in ur on of key. if not comming check key pad strips. mostly it prob from key pad may be it is not good connected to board or damage during assembling. first unplug it and then re connect
Mar 23, 2007 | Motorola Mobility RAZR V3
Motorola razor v3 display problem
If the charger is not an original motorola charger,, then you have a problem. make sure its original.
Oct 11, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
