Question about Samsung Televison & Video
The tv turned itself off and back on again now the sound is ok but no picture.anyone know why.
  • 585 Answers
Sounds like the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
both are serious , also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swolled on top and are easy to solder in cost about $1 E
Posted on Aug 01, 2009
3 Suggested Answers
pjbaldi
  • 8 Answers
SOURCE: dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Posted on Jun 02, 2010
  • 8909 Answers
SOURCE: turned tv on 2night had
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Posted on Mar 16, 2011
HI - I HAVE SOUND BUT NO PICTURE - COMPLETELY BLACK.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
Nov 25, 2017 | Televison & Video
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
No Picture now No Sound
main board faulty check tuner poss dry joints
Nov 22, 2012 | LG 37LC7D 37 in. LCD HDTV
JVC LT47 that picture goes black (sound fine) after being on for awhile. Can turn TV off, then back on & it's fine. But then happens again about ever hour or so.
Hello
Hello
It is due to some loose soldering points [dry soldering we say it technically], in the power supply section of the TV. Just check for it. Check the solderings of all components, that will heat up to an extent when the TV works on. Repeated heating and cooling may make solderings to the terminals of that components to get loose. Just resolder all the suspected solder terminals, by applying a little more solder, without making any solder bridge short in between adjecent solder terminals. This must solve the problem to your tV. OK.
Feb 11, 2012 | JVC Televison & Video
Turned tv on 2night had picture and sound for approx 3 minutes then tv turned itself off had 2 flashing red lights turned tv back on no picture or sound then turned itself off again
Mar 16, 2011 | Sony Televison & Video
Samsung lcd tv le32r8
perchè quando collego il computer al televisore l' audio è assente?
Oct 15, 2007 | Samsung LN-R409D 40 in. LCD Television
TV won't stay on
sounds like a deflection/convergence fault.requies service
Sep 08, 2007 | Toshiba 56HM195 56" Projection HDTV
TV turns itself off after a few seconds, no picture at all
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Sep 13, 2006 | GE 32GT740 32" TV
Pt 56tw53 picture trouble
I had the same problem with my TV, It seems the high voltage trasnformer blew which in turn casued the pin cushion?? to blow. It then shuts the tv off to prevent more damage to it. $500 with service charges to get it fixed!
Nov 05, 2005 | Panasonic PT-56TW53 56" Rear Projection...
Televison & Video Logo
65 people viewed this question
Jerry Greenberg
Jerry Greenberg
