Question about Whirlpool Washing Machines
Whirlpool washer stops after agitation cycle
I have a Whirlpool Thin Thin stackable unit. It had a leak at the lower front. I traced the leak to the water pump. I replaced the pump and the leak was resolved. I then started the unit and a new problem surfaced. The Agitation Cycle started as expected and ran for approximately 6-mins before the unit completely stopped. The timer continued running, but all washing stopped until the timer approached the Rinse Cycle. Agitation began again during the Rinse Cycle for approximately 4-5 mins, and then stopped again. The tank is still completely full of water at this point and has never dumped. No other action occurred as the timer went through the Spin Cycle untill reaching Off. The whole process completed with water remaining in the tank. The lid was closed to activate the lid switch during the process. The problem is repeatable and predictable in all mode settings. Please help. Thanks.
  • 29 Answers
Maybe check the belt is it cracked worn or fibers showing if so replace it
Posted on Jul 28, 2009
Started a quick was cycle to test washer without cloths. It agitates for about 10 seconds, stops for 5 seconds and agitates for 10 seconds again. The light array is suggesting it is going from wash.
new washers usualy start a brief agitate then locks the door and then starts watering again. depending on washer model it can do this a couple times to evenly soak the clothes at the start of a wash cycle. it is advised to not run full cycle in the washing machine with no clothes for it can damage the unit.
Jul 07, 2016 | Whirlpool Compact Stackable Front-Load...
Water won't dump
When you replace the pump, always to remember to makes sure the pump is pushed all the way in so that the shaft has a good grip. Try taking it out and pushing it all the way in. The 4 legs should touch the motor, as you put the 2 little clamps on the top and bottom.
Good luck, I'm pretty sure it's something really basic with the pump :)
Jul 19, 2009 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
GE Spacemaker stackable washer/dryer
The front cover come off by removing two philips screws on the bottom of the panel. That will expose all the operating parts of the washer.
Sep 17, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
Not spinning
YOUR LIP SWITCH IS BAD REMOVE FRONT PANEL,TRACE WIRE FROM SWITCH TO JACK,UNPLUG,ON MACHINE SIDE CUT BOTH OUTSIDE WIRS AND WIRE NUT THEM TOGETHER,TAKE SURE UNIT IS UNPLUGGED FIRST,YOUR DONE,THANKS-MIKE
May 04, 2008 | Whirlpool LTE5243D Top Load Stacked...
My washer does not work
Sounds like you may have a lid switch problem. Without a model number, I really can give you a part number (Kenmore Stacks are made by two companies, Frigidaire and Whirlpool) or a way to get to it. It is right under the lid. Check the top and be sure that the plunger that goes into the hole isnt broke or missing. If you need further help, send me the model number (will start with 417 if its a Frigidaire or 110 if its a Whirlpool) and will try to get you a little more information. The job on either unit isnt that hard, and parts are pretty inexpensive. Let me know. Jim
Dec 13, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
183 people viewed this question
Dan Webster
Dan Webster
Sal De
