Question about GE Profile Spectra JGBP90 Gas Kitchen Range
The oven keeps beeping. The burners work, but nothing works for the oven. If you press clear it stops for approx. 10 seconds and then starts beeping again.
    Brigadier General:
  • 3,917 Answers
The major reason for this would be the control senses oven temperature above 615F-630F. shut down the breaker switch asap.
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Thank you for contacting Fixya.
Posted on Jul 26, 2009
After broiling steaks, f10 appeared on screen and constant beeping since. 1-2 hrs now. turned off electricity and keeps beeping.
Press the Stop/Clear button. If that doesn't work, press it and hold for 3 seconds. If you get a fault code, something is broken. If it is associated with broiling, the first thing I would check is the broiler temperature sensor. Is there a buildup of grease on the ceiling of the oven?
Jan 10, 2011 | Kenmore 47783 Electric Single Oven
Tried to do self cleaning on oven, about 10 minutes in got "f2 locked door" and it won't clean. what is that all about?
Error code F2 on clean cycle is indicating that the maximum permissable cleaning temperature has been exceeded. (or it's got too hot!)
However it seems unlikely that that would happen in just 10 mins. more likely it is a problem with the oven temperature sensor which should be checked over as should the lock switches..
Dec 14, 2010 | GE JRP24 Electric Double Oven
Whirlpool Microwave Hood Combination MH3184XPS-0 (October 2004), for no reason at all, this morning keeps beeping and running the power setting down from 10 to 1, and just keeps doing it in rapid sequence....
Ours just started doing this exact same thing this past Friday - 12/11/09. What's going on? The cook power just starts beeping all by itself and going from 10 down to 1 over and over again. It may stop momentarily, but then starts again within a minute or so - it's constant until we unplug it. We plug it back in and within a few minutes it starts doing it again. What gives?
Dec 08, 2009 | Whirlpool MH3184XP Microwave Oven
What does the error code F1 indicate, on a Wolf Oven?
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Mar 24, 2009 | Ovens
Says ''Locked'', and we can';t Unlock it.
hi my name is mark, you can try pressing the start button and hold it in for about 5 seconds. without make or model it might work. thanks for your question.
Mar 16, 2009 | Microwave Ovens
Kenmore elite 790.3670 oven door locked
I held down the clear button for three seconds, it unlocked but still showed the lock button lit. It began beeping over and over. I opened the door and pressed the clear button again for three seconds. It stopped and the oven works just fine now. In fact, I used it right after I got it cleared out.
Feb 07, 2008 | Kitchen Ranges
Kenmore Elite Electric Range, Display stuck on LOC
I pressed the lock icon on the panel and held it for a few seconds and the display cleared.
Feb 03, 2008 | Kitchen Ranges
Kenmore electric range 911.9369181
F8 Failure of Electronic Range Control (ERC) Replace Electronic Range Control/Clock (ERC)
Dec 01, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Oven timer goes off when not being used
I have the same problem with the beeping and screen flashing F1 does anyone have a solution yet?!
Aug 22, 2006 | Magic Chef 9512 Electric Single Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
196 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
