Question about Emerson Televison & Video
Emerson DORA TV/DVD Combo cant get channel 3 or 4. when I try to change channels I get 6, 10, 74 & 124 & nothing else- anybody know how to fix this?
MikeNJ1964
  • 398 Answers
SOURCE: I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
Posted on Aug 05, 2007
SOURCE: Lost factory remote
you need the remonte control original bath this situesen you need the selection deader cod four your remont controler
Posted on Jul 12, 2007
mattballew
  • 89 Answers
SOURCE: cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Posted on Nov 25, 2008
freetek
  • 5568 Answers
SOURCE: programming cable channels for emerson tv vcr dvd combo
To see RCA's code list you probably need their website but Emerson is one of several names now owned and built by Funai, who also builds Symphonic & Sylvania.
You might want to try those codes with your set.
Posted on Dec 18, 2008
  • 9 Answers
SOURCE: I DONT TUNING THE CHANNELS
Your problems can be solved by using the menu setup on your tv. Spanish is an option you can choose.Also on the menu you select air(antenna) or cable,then choose auto scan.The tv will pick up all channels available in you area.
Posted on Jan 03, 2009
Channel setup without remote
Hi I attached product manual link for your Emerson EWC19T4.
I believe that you can find solution.
pdfretriever com
Mar 25, 2014 | Emerson EWC19T4 19 in. TV/VCR/DVD Combo
I cant get my did/vcr combo to play on my Emerson TV. I all color coded cables attached. Help!
Not enough information for a good reply. Are you sure your tv is set to the correct mode or channel for vcr? Make sure both devices are on, your dvd/vcr playing if you can, and see if the tv on channel 3, channel 4 or channel 91 show that dvd/tape. Otherwise, try checking your remote control, MENU button and look for device options, or INPUT options, on the main menu.
Mar 09, 2013 | Emerson Televison & Video
I brought my daughter a dora the explorer tv/dvd combo dte313 and she broke her remote so im not able to switch from tv to video or get all the cable channels. what should i do?
Hello and thanks for using Fixya.com ..Most remotes are able to withstand droppage .If remote was dropped and if your kinda handy.You can try to pry open the remote .Lots of remote have simple issues like ,bad solder joints battery terminal bad .If not the other option id to take remote to a local tv shop and ask if they can try to fix it .This will usually cost you a few dollars.But this is better than ordering a new remote.Last option would be to order a remote or try to find a universal remote that will work with your set..Goodluck
Sep 25, 2011 | Emerson Dora The Explorer DVD Player
Need to know what channel my TV needs to be on to watch DVD/VCR
The channel you use depends on how you have the vcr/dvd player wired to it. If you used a co-axial wire, then your tv should be on channel 3. If you used RCA wires, then you will have a button, either on the front of the tv, on the remote, or both that says "input" or "source". Pressing this will change the TV to the rca connectors. Try this and let me know if it helps :)
May 16, 2009 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Connecting digital converter,Emerson VCR/DVD Combo,Sony SDTV
I think you may need an RF Modulator. This device will have connections for the DVD and TV and will have a channel 3/4 switch. Good luck to you.
May 15, 2009 | Emerson EWR20V4 DVD Recorder/VCR
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Cant see dvds on my emerson tv
Hello.
In many cases by connecting the DVD via a scart cable (depending in what country you live in if your system supports it)
the dvd will send a signal to the TV to switch over to RGB mode when you start playing the dvd. Rember to make sure the scart connectors are firmly pressed into their sockets on both tv and dvd.
Also if you found out how to switch channels directly on the TV try to go through them ...you might find the AV channel that will show the picture from your dvd.
Hope this will help you.
Good Luck.
Feb 13, 2009 | Emerson EWF2704 TV
Cant turn the tv to channel 3
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
Remote for the emerson Dora the Explorer tv/dvd combo
You can get an original Dora the Explorer remote for this television at remotes.com. That's where I got mine.
Feb 02, 2008 | Emerson Dora The Explorer DVD Player
Televison & Video Logo
117 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
