have you seen the tub spin? if not, its possible its draining, but not spinning...these machines can drain and leave clothes wet. is this what its doing? if it is spinning..i'd say something is blocking the flow..like a kinked hose., or clothing blocking the flow before or ater the pump..have you seen the tub spin? if not, its possible its draining, but not spinning...these machines can drain and leave clothes wet. is this what its doing? if it is spinning..i'd say something is blocking the flow..like a kinked hose., or clothing blocking the flow before or ater the pump..
You can't post conmments that contain an email address.
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with either the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Have you called Daewoo Customer Service they make this product for Crosley the number is 877-393-7823 Also have you checked to see if anything is stuck in the pump.
FL is a flood condition fault, too much water in unit. i would turn off water supply and try to spin water out. select spin button, should put 8 min on timer try startin that water should pump out then if not you got somethin stuck in pump (lint likely)
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
