The wireless airport is on and says that it is connected, but it will not allow me to access the internet without the ethernet cable. Why?
  • aa1Consult May 11, 2010
    are you talking about an air card or is this just a standard wirelss device?
  • 611 Answers
Just close the firewall in the laptop or desktop or disable the any anti virus also then they allow
Posted on Jul 29, 2009
Cisco access point
How to configure wireless access point using a laptop
Wireless technology makes connecting to the Internet possible from anywhere within the range of the network. Unfortunately, not all Internet-capable devices have wireless technology, and many still require an Ethernet port connection. If you have a laptop with a wireless card and an Internet connection, you can make the laptop a wireless access point and share that connection with other devices, whether your laptop runs a Windows or OSX operating system. Windows computers allow other devices to access the wireless network via a physical connection to the laptop, while OSX computers allow AirPort equipped devices to connect as well, creating a second wireless bubble for the network.
Instruction:
WINDOWS
1 Turn on the laptop and the device with which you will share the connection. Ensure the laptop's wireless card is turned on and you have an Internet connection.
2 Connect an Ethernet cord to the port on the laptop, and the other end to the receiving device. You need to make the connection first, or you will not be able to access the sharing options for the connection.
3 Open the list of network connections on the computer. In Windows 7 and Vista, access this list by typing "Network Connections" into the Start menu search bar and pressing "Enter." In Windows XP, click on "Network Connections" in the Network and Sharing Center section of the Control Panel.
4 Right click on the wireless connection and select "Properties," then navigate to the Sharing tab. This tab will not appear unless both devices are connected.
5 Check the box marked "Allow other network users to connect through this computer's Internet connection." Click "OK" to save the changes.
OSX
1 Click on the Apple menu and select "System Preferences." Click the "Sharing" option, then choose "Internet Sharing."
2 Select the Airport and wireless network in the "Share your connection from:" drop-down menu.
Select an output format for the connection in the "To computers using:" drop-down menu. Choose "Ethernet" for a physical connection or "AirPort" for wireless broadcasting.
Turn on the device you wish to receive the connection. Connect the devices with an Ethernet cable, or turn on the receiving device's AirPort card and connect wirelessly.
Dec 12, 2011 | Computers & Internet
Tip
Share Your Internet Connection with More Than One Computer- The Easy Way
Here is a simple way share your home internet connection with more than one computer. This will work for both wired and wireless and doesn't require alot of technical or computer skills to accomplish. I'm sure there are other ways, but if you're looking for a simple repeatable setup, here it is.
If you've got a dsl connection through a dsl modem, this TIP will work for you.
If you've got a cable modem, this TIP will work just as well.
Here's a list of what you'll need.
  1. Dsl or cable modem that works on your system and you can access internet with one computer (If you're using the internet, most likely you've got this already).
  2. Wired (Ethernet) or Wireless Router (wifi routers have 4-6 ethernet ports also).
  3. For Wired: Ethernet cable to connect modem to router.
  4. For Wireless: Wifi compatible computer or wifi card for your computer (follow manufacturer's instructions for proper install).
Procedure:
  1. Turn all components off. This includes anything on your existing network- computer, modem, printer and any router you may currently be using.
  2. With all power off, connect an ethernet cable between your modem and your new cable/dsl router(wired or wireless).
  3. Turn on the power to your new router only and let it boot up completely.
  4. Turn on the dsl/cable modem and allow it to boot. Since the router was booted first, the modem with recognize the router's MAC address (ethernet numerical address) and connect that address to the internet.
  5. Connect all the other components onto the router with the ethernet cables as needed and turn on the components- no particular order is necessary after the router and modem are booted. Your router will assign MAC addresses to all the ethernet components. Once the MAC address is assigned, your computer should work correctly with the internet and shouldn't drop out when the second computer is turned on.
  6. For wireless connections, boot up your computer with the properly installed Wifi card, airport card and allow it to "find" your router. Once you get confirmation of the signal, you're good to go.
Following this procedure will allow your modem, your router to use their designed software to connect you without a bunch of programming. You will actually enjoy having more than one computer sharing an internet connection.
Remember this procedure and follow the steps again if you lose power and have to reboot your network.
on Dec 04, 2009 | Computers & Internet
How can you use public access on your desktop and netbook with a netgear router and adapter walmart sales lady said it can be done with just the router and adapter setup everything we needed was in the...
Just having the wireless router without connecting it to cable modem or DSL modem will not allow you to get onto the Internet. The wireless card in your computer/laptop will allow you to get onto the Internet at a free public WiFi hot spot location such as McDonalds, Star Bucks, at the airport.
Also the wireless card in your computer/laptop may allow you to connect into an unsecured wireless router from your neighbors, if their wireless router is within range of your computer/laptop but without their permission to use their Internet, it is considered stealing from your neighbor. They have a set download limit from their Internet Service Provider and by you connecting to their ISP you may cause them to exceed their download limit and they would be charged additional costs for every Mega byte over their limit.
Sep 28, 2010 | NetGear RangeMax Dual-Band Wireless-N...
I f I connect hotel internet via Apple USB 2.0 Ethernet Adapter to my MacBook Air, internet after few minutes disconnected, to connect again i take out the cable, and then plug in, usually internet start...
Try turning off Airport. Your computer may be finding a wireless network and automatically switching to it, and getting an intermittent signal. Just a guess, but for a good ethernet connection you want to disable the Airport searching feature anyway.
Open the System Preferences application, select "Network" and right on the top left of the resulting window there's a pretty big button that will either say "Turn Airport On" or "Turn Airport Off" - just turn it off if it's not already ...
Hope this helps!
For help with Public Address Systems see my new How To Video, available as a DVD at www.whamuniversal.com
Feb 15, 2010 | Apple USB 2.0 Ethernet Adapter for MacBook...
Airport utility cannot find airport express - ask for rescan
connect a ethernet cable to it. find it in the utility and reset it.
Jun 07, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
New Apple Airport Express Base station blinking amber light
Using the Airport utility on your macbook (located in your Utilities folder) will tell you what the conflict is.....most likely you have DHCP issue or the network is at the incorrect setting.
The wizard in the utility will tell you what you should fix.
Jan 05, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
DI 524 and airport express
Yes, that is possible for as long the DI524 is already properly setup and can provide already internet connection everything should be working fine there....
Nov 10, 2008 | D-Link AirPlus DI-524 Wireless Router
Please can you tell me how to setup a huawei EchoLife HG520b Broadband wireless router. Thanks
You need to follow the below steps to enable you to go wireless, connect your PC and Router via the Ethernet cable.
1. Open any web browser and in the address bar type 192.168.1.1 and press Enter.
2. You will now get a login screen appear, the username and password to access the router is " admin "
3. Click on Basic then Wireless LAN.
4. Make sure Access Point is set to enable.
5. SSID is your Network name and can be changed to anything you like.
6. Make sure Broadcast SSID is enabled.
7. Set Authentication type to WPA
8. Set a password in the Pre-Shared key section between 8-64 letters/numbers long-this is your wireless password, keep this safe as only you have access to this password.
9. Click submit at the bottom of the page.
Your router has now been setup for wireless and is protected by WPA security.
To Allow your PC to connect wireless:
1. Remove your ethernet cable and turn on your wireless on your PC.
2. In the bottom right hand corner of your PC right click on your wireless icon and select "view wireless networks in range"
3. You should see your wireless connection because the SSID should be displayed.
4. Right click on your network and enter the wireless password and then click connect (If right clicking brings up no options then double left click).
5. You should now be connected in a wireless state.
To Allow your MAC to connect wireless:
Please first update the MAC, click the apple top right and update software.
1. Remove your ethernet cable and turn on your wireless on your MAC.
2. Top right click on the airport icon.
4. Click on your network and enter the WPA password and then click connect.
5. You should now be connected in a wireless state and the airport icon will turn black.
If you have not yet entered your ppp details (username and password for internet connection) select basic and then wan settings you can change all the settings for your connection here
Hope this helps
Nov 06, 2008 | Computers & Internet
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Remote access to my work desktop
Your modem is what connects you to the internet, your Mac airport is a router...One of the quirks about Apple's AirPort Base Stations is that they are routers, but not modems. As a quick refresher: a router enables you to create a network that connects various devices together (Macs, iPhones, iPads, hard drives, printers and so on); whereas a modem connects your network to the wider internet.
Feb 05, 2018 | Broadxent Computers & Internet
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
