Question about Briggs & Stratton Garden
Gas in oil 12.5 hp briggs and straton will not start
  • 202 Answers
The float in the carb is stuck open, its flooding with gas. the gasoline is going past the rings and/or valves into the crankcase. you need to remove the float bowl and unstick and reset the float to specs, maybe a new seat and needle and change the oil before restarting.
Posted on Jul 26, 2009
  • 33 Answers
This is a typical problem with older Briggs & Stratton carburetors. The easiest fix is to install a shutoff valve in the fuel line between the tank and the carburetor. This will stop the fuel overflow when not running. Then change the oil to remove any gas from crankcase.
Posted on Jan 31, 2015
How to repair gas in oil problem for 21 HP brigg and straton engine
Most times a good cleaning and rebuild of the carburetor will fix this problem. Most it is the needle valve and seat that leaks.
One extra thing to check if this engine has vacuum operated fuel pump is see if fuel pump diaphragm has ruptured or not. If it has ruptured fuel can get into the crankcase via the vacuum hose.
Oct 10, 2014 | Garden
Engine cranks but does not start on 21 hp briggs and straton
May have oil in the carb. If it smoked its burning oil due to having to much in it.
Jul 02, 2013 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
Oil leaking out exhaust
when the piston rings get worn, the oil seeps past them, and into the exhaust manifold through the exhaust pipe. you need to change the piston rings.
Jun 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Pony Garden Tiller: does a tiller with a briggs and straton engine nee...
The pony tiller with a Briggs and Stratton engine only uses gas do NOT mix oil with the gas.
Frank
May 18, 2010 | Troy-Bilt Pony Garden Tiller
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Jul 15, 2009 | Mtd Garden
I have a murray 22 inch lawn mower with a 4.0 hp briggs and
Change your air filter, spark plug, fuel filter, and oil. Then make sure the gas is fresh. Gas starts going bad after a month. Spray carb cleaner in hole underneith the fuel filter. Oh yea dont put more than 20oz of oil in it.
Mar 27, 2009 | Garden
GAS LEAKING OUT OF TANK INTO CRANKCASE IN A RIDING MOWER
Gas in the oil usually means the carburetor float is to high or the float is sticking. Hope this is of some help. donnyb60
Mar 21, 2009 | Briggs & Stratton Garden
Garden Logo
1,461 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
