Question about Sony Playstation 3 (PS3) Console
PS3 is backwards compatible with PS2 games, and USED to play them
Basically, my PS3 has been playing PS1 and PS2 games for over a year. I move the system to my new apartment, hook everything back up how it was before (when it worked) and suddenly, the PS2 games will show the Playstation logo screen then it will go completely black - and only the sound will come through.
Common sense tells me that perhaps there is a problem with my HDMI cable and perhaps the PS2 can't read through it - but then why have the logo screen come up? And even worse, why have worked before this point?
It is not the PS3 - and it is not the PS2 disk, it has to be something within the settings. I could try taking it out of the HD output and see if it'll work, but it was working fine with the HD output only four days ago.
No damage has come to the system - and it plays PS3 fine. I recently updated it to work online, but it wouldn't work even before I updated it - so I doubt that's an issue.
Any suggestions before I boot it out the window?
  • 4 Answers
Did you get a fix for this yet? What TV are you using? I have the same problem, and it has to do with a system update. When we first bought the PS3, it did this, then one of the system updates fixed it, and it worked fine for well over a year, until a recent system update which I assume changed something about how the PS2 games are read or rendered. I can now play them only through the component cables, which doesn't give me nearly as nice a picture. Any help with this would be appreciated. (PS2 SYSTEM DATA doesn't help).
Posted on Sep 07, 2009
In Playstation Store, you should download (for free) the PS2 SYSTEM DATA (something like this).
if you have formated your system, the files were erased, and the games won't play until you download the backwards comparibility files again.
Posted on Jul 26, 2009
sgregg
  • 133 Answers
SOURCE: Ps2 will not save ps1 games...
no u need to use a ps2 card i hd the same problem
Posted on Jul 31, 2007
Cerfer39
  • 709 Answers
SOURCE: My PS2 will not play PS2 games, but it will play PS1 games
Hi
If it will play DVD's this is a good sign. You will only need to clean the lens of the laser. Also clean the hub that the Disc rides on.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. REmove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. REmove the little white disc from the Cd tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and your in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Posted on Nov 05, 2007
Cerfer39
  • 709 Answers
SOURCE: PS2 reads ps1 games but not ps2. Clicking noise
Hi Jstpd,
Boot up your PS2 with no disc in it. Press the Traingle and highlight the top selection. Press the triangle again and then press X then select ON and press X. This should turn on Diagnostics. Do not reboot the PS2, just put a PS2 disc in. This might get it reading PS2 discs again.
If this does work you can follow the procedure for cleaning below:
  4. Remove the Warranty sticker to the right edge of the power socket.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  10. Remove the little white disc from the CD tray lid.
  13. Do not adjust the white gear at the top of the Laser tray. This is a critical setting that may mess up everything.
  14. Put it back together, and you’re in business.
Posted on Nov 11, 2007
SOURCE: ps1 games wont play on slimline
u must reset it twice
Posted on Nov 25, 2007
  • 91 Answers
SOURCE: my ps3 used to be backwards compatible for ps1-ps2
is it the 60 gb model?? that is the only one that did backwards compatibility. all others dont. if u do have the old 60gb then maybe sony got rid of it on the firmware updates. go on the ps3 website and update an older firmware and see if that works.
Posted on Dec 31, 2009
Fully backwards compatible ps3 shuts down with 3 beeps and flashing red light when trying to play ps1 games
Hmmmnnn, consider the reason they pulled the rev compatible system off the market. It is possible to be getting the symptoms of YLOD without it actually happening with some games. The older games spun faster(sometimes) and made the system work harder. It could be heating up and shutting down right at the point of failure. I've seen 2 different revers compatible systems YLOD the same way. Good luck.
Apr 06, 2013 | Sony Playstation 3 (PS3) Console
I thought playstations are all formated to play any made of equal or lesser p.s. value such as p.s.3. should play p.s.2. games
I believe you're asking about backwards compatibility. While I agree a PS3 should be able to play PS2 games, it's sadly not always the case. While they all can play PS1 games, not every PS3 can play PS2 games. PS2 compatibility depends on the model.
Backwards compatibility with PS2 games has slowly been phased out. The original PS3's had hardware emulation (quite literally there is a PS2 inside of your PS3). The later revisions had software emulation only (PS3 processor pretends to be the PS2 processor), and then none at all. No slim PS3 has backwards compatibility.
Hardware emulation:
20 GB PS3 Fat/Original - Model CECHB01
60 GB PS3 Fat/Original - Model CECHA01
Software emulation:
80 GB PS3 Fat/Original - Model CECHE01
In my personal experience, there's no real difference between software and hardware emulation in terms of actual game play. Software emulation has a few hang-ups on some older games, but overall it works pretty well. And it's infinitely better than not having any ability to play PS2 games at all.
Links!
Wikipedia
Hardcoreware.net - Comparison Table
Sony - check compatibility of games with PS3
Hope that helps!
Sep 30, 2011 | Sony Playstation 3 (PS3) Console
Can i still play my ps2 games on my new ps3??
Hello, unfortunately most PlayStation 3s are not backwards-compatible. The 60GB PlayStation console is but it is very expensive as they are very limited edition.
Jun 11, 2011 | Sony Playstation 3 (PS3) Console
Can ps2 games be played on a ps3 and if yes how
Hi, the only ps3 that can play ps2 games is the 40gig one this is the only one they made that was backwards compatible you could also play ps1 games on this ps3, how ever they are hard to come by now and the only real place you can get one from is the well know auction site.
The other thing you could try would be to go into your nearest game shop and ask them if they can get a backwards compatible ps3 they are out their but are hard to come buy new.
their is also ways of changing the firmware on your ps3 to accept the old games how ever doing this is illegal and i cant give you any advice on this as its banned by the site, how ever if you use google and type in how do i make my ps3 backwards compatible this will then list loads of sites that can offer the help your looking for
Jul 07, 2010 | Sony Playstation 3 (PS3) Console
My ps3 won't let me play ps2 games. is there anything that can be done?
Unfortunately, no. Sony built the PS3 to only play PS3 games, so no backwards compatibility. Maybe in the future though, they might release an update.
Dec 29, 2009 | Sony Playstation 3 (PS3) Console
Can PS2 games be played on a PS3?
It depends on what PS3 you get. The PS3 slim does not offer backward-compatability to PS2 games. You can play PS1 titles.
Here is a link to a page that goes more into detail about what to buy. There is also a link on the page that will show you what games can be played on what PS3. http://thirdworldgeek.com/is-your-ps3-backward-compatible/
The second link I talked about is the picture of Megan Fox(He's telling the truth, it's not a porn site, he just likes Megan Fox.
Nov 12, 2009 | Video Game Consoles & Games
Can ps2 games be played on ps3
on the first ps3s but not now......im not sure bout the slim......mine plays ps1 2 3
Nov 11, 2009 | Sony PlayStation® 3 (60 GB) Console
What games beside ps3 games are compatible with the ps3
It depends on your system the 40g will play ps1, but not ps2. The 60g or above will play both.
Sep 15, 2009 | Sony Playstation 3 (PS3) Console
Ps3 will not play ps2 disks will play ps3 disks ok
playstation 2 games will only play on the 60gb ps3 the orginal console.
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
Ps3
40gb is not backwards compatible, it cannot play some ps1 and ps2 games, the 60gb is though.
May 31, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
299 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
