Question about Porter Cable Saws
The shaft that holds the blade broke. i ahave a new one but am having trouble dissasembling the saw
  • 2 more comments
  • mike832 Jul 27, 2009
    it is a porter cable 737 tiger saw
  • mike832 Jul 28, 2009
    rowdy
    i already have that i need to know how to take out the bolt labeled 125 on the parts breakdown. When you turn this it turns the gears and there does not seam to be a way to lock this to remove the bolt. I need to take this out to remove the shaft that i need to replace. am i doomed to spending more then the saw is worth to have a repair shop do this.
  • David Ford
    David Ford May 11, 2010
    what is the brand and model number and I will try and find a breakdown and help you with it.
  • 2,176 Answers
I would recommend going to Dewaltservicenet.com and typing in your model number on the following page you will need to click on your type number for the schematic. their schematics are really detailed and after reviewing if you still have problems let me know.
Posted on Jul 27, 2009
  • David Ford
    David Ford Jul 29, 2009
    couple different ways now that Iknow your problem, can you lock the spindle in vise? if too short remove the gearcase and put a shop rag around the gear or an old piece of innertube or something rubber to keep from damaging teeth and gently lock in vise and remove bolt or what I have done us use an impact wrench to hit it real quick to loosen.
The motor runs but the blade does not turn
UNPLUG the saw! IF your saw is a direct drive; either the blade is loose or the center of the blade is broken, Or the motor shaft has broke off. IF your saw is BELT DRIVEN, check the belt tension, or belt condition.
Jan 20, 2014 | Delta Saws
I need directions on how to change the baldes on a reciprocating saw.
There are 2 types of clamps that hold the blade in that type of saw.
Since this one most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
If your tool doesn't have this style then it should have a twisting clamp. This will rotate and release the blade. Sometimes a pliers is needed to loosen the collar, but not to tight tho.
Jun 30, 2011 | Skil 921502 85 Amp Reciprocating Saw
I have an old Sears Craftsman 7" Electric Handsaw model #315.27782. The blade I use for fine sawing has begun to wobble. I've taken it off, put it back on and tightened it several times. Same wobble. ...
It could be that the bearings that support the shaft that holds the blade are worn, allowing the shaft to move slightly and make the blade wobble. As the machine is an older model, I would try replacing the bearings.
Sep 16, 2010 | Craftsman Saws
I bought a Dewalt DW310 reciprocating saw and there seems to be no way to install a blade. The instructions show a wheel to turn to unlock the blade chuck but the wheel is up inside the saw body where you...
The blade clamp collar is a spring loaded knob of sorts that holds the blade in place. If you are not able to pull the blade shaft out of the saw to get at it, plug the saw in and hit the on/off trigger a few times to get the shaft and knob out of the body of the saw. Once you can get at the knob it should be easy to turn it and insert a new blade. Let me know if you have problems.
Aug 30, 2010 | Dewalt DW310K Heavy Duty Reciprocating Saw...
Looking for shaft lock to change the blade on MK 170 wet saw
Just use a rag and grab the blade. Unless the threads are messed up you don't have to hold the arbor still, just the blade.
Apr 27, 2010 | Mk Diamond MK - 170 Wet Cutting Tile Saw
My Craftsman 8 1/4 Radial Arm saw
tighten retaining bolt if still spins remove bolt and add a washer to the out side of blade between the bolt head and retaining washer and retighten
Jan 29, 2010 | Craftsman Saws
Blade Slips Off
The two Wheels must be in line to each other, has one of the wheels moved? Does the missing screw clamp the wheel to the shaft? If yes you MUST replace the screw.
Aug 05, 2009 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Blade replacement on mk-170 tile saw.
take a pair of good vise grips and hook onto blade tightly, slide uo against back braket. that will hold the blade from spinning while you remove the nut, try bumping your ratchet/ wrench w/ a rubber mallet or hammer. hope this helps
Oct 29, 2008 | Mk Diamond MK - 170 Wet Cutting Tile Saw
Changing a miter saw blade
lefty-loosey (counter-clockwise). There will be space on the inside of the blade for another wrench to hold the shaft while you loosen the nut. If you've never done it, then you might want a pair of gloves; the blade might be dull on wood, but it'll be sharp on hands!
Aug 03, 2008 | Electrical Supplies
Saws Logo
151 people viewed this question
Top Porter Cable Saws Experts
Dave
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
