Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Can't Network Print
Hi All,
I'm trying to set up the Bizhub C350 as a Network Printer.
Drivers are all set up on the Server but not connecting to The Printer.
On the Admin Menu General Settings, There is no option to set up Network IP.
Is there a Reset to Factory Setting function. I've loged on as Engineer and used every combination of set up of periphrals, but to no avail,
Anybody ahd a similar problem
Best Regards
John
  • sourceone Aug 25, 2008
    In admin mode there is no option for network settings to configure IP. IC-401 is installed on this machine.
    Thanks!
  • Anonymous Mar 21, 2014
    In admin mode there is no option for network settings to configure IP. Konica minota 451 is installed on this machine.
    Champion:
  • 214 Answers
In printer you should log in as administrator and there should be network settings, where you can put in ip address and gatway and so on.
Posted on Dec 05, 2007
  • 167 Answers
The IC-401 (Fiery) has it own set of parameters and menu.
On the LCD panel press the controller icon and a display screen will appear. This is where you configure the Fiery.
It runs independantly from the settings found in the MFP's Utility menu.
Once you set up the network, you can configure the Fiery fully through your web browser by typing in the IP address and clicking on the "webtools" icon. This will produce a pop-up window so have the blocker off.
Posted on Aug 26, 2008
I cant add my bizhub c350 to google cloud print
Mite try going to the konicaminolta website to see if they have any drivers for that machine. Mite be to old and best can windows 95 or XP.
Jul 21, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
C350 driver
To offical konicaminolta website drivers are free.
Apr 10, 2014 | Minolta C350 Printer
Hi can a Matching paper size is not available cause a printer konica bizhub c350 to be offline?
If your copier is connected to your network and you get this error, the answer is no. If you are getting the miss match error then the print job could be stuck in the que. This would cause it not to print. If you dont know how to clear the print job, restart your computer and try to print again using the correct paper size.
Mar 08, 2011 | Konica Minolta DiALTA Di183F Copier
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Mar 30, 2009 | Konica Minolta bizhub C351 All-In-One...
Bizhub C350 - Print spooler not running after power outage
I would print out a copy of the network configuation of that printer and ensure it has the proper network settings (I.E. IP address, Subnet mask and Default Gateway. I just worked on a printer that I accidently pull the plug on and it lost it's network settings and wouldn't print until I changed them back to the correct settings.
Good luck
Nov 11, 2008 | Minolta C350 Printer
Printer will not print ' Print Error'
Can you ping the printer?
If not, then check settings or for conflicting IP address.
May 20, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
831 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
