Question about Epson PictureMate C11C623001 Photo Printer
Epson PictureMate - can't clean all nozzles & Error P
My pink nozzle is clogged (I gather) and after many Print Head Cleanings I now get a Code P - replace cartridge - when changing the cartridge, the error doesn't go away. Now I can't get past the error code to continue to clean heads even though I'm not making any progress with the pink nozzle. Any suggestions?
  • Epson Master
  • 511 Answers
Many times head cleaning will throw much ink away. 1 time about 10% of ink. After meny times head cleaning, ink will out, and need replacement. May be after head cleaning nozzle is ok, but after replacement, printer do ink charge. It may be distrub the flow of ink at head. Is the cartridge new?. Use CISS for continuity printing.
Posted on Jul 27, 2009
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
I put in new ink cartridges and the cyan pink won't work.i have a lexmark prevail pro705.
Hello Rina! Welcome to FixYa!
If you have changed Ink Cartridge and after changing Cyan Pink is not printing then you may resolve this issue by Cleaning Print Head, Sometimes due to clogged print head nozzles this problem may happens. By cleaning the Print head Nozzles, This problem may resolve.
From the Printer Control Panel, Navigate to Maintenance, Press Up and Down arrow button to scroll Clean Print head or deep Clean Print Head and then Press OK.
Now try to print again. I hope this issue will be resolved
I hope this solution helps you and you have clear picture in your mind
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Team : FixYa
Feb 14, 2012 | Lexmark Office Equipment & Supplies
Clogged print head
Put the black ink cartrige nozzle in warm water and wait several minutes.I don't know if this will work in your case but you should try it. I had similar situation and this helped.
Dec 15, 2011 | Epson Stylus Pro 4800 InkJet Printer
I have been using an epson stylus color 880 for years. One day it would not print. Replaced the cartridges and still will not print. It goes through the printing procedures but nothing shows up on...
The print head nozzles may be clogged. From the Utility section found in the EPSON printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, try replacing the ink cartridge. Any ink cartridge installed into the printer must have a blue label on top of it. If the blue label has been removed from the ink cartridge, do not install the cartridge. Using an ink cartridge, which does not have the blue label on it, may damage the printer. Caution: If you have already installed a cartridge which is missing the blue label, or if a previously installed ink cartridge was missing its blue label at the time it was installed, and now head cleanings do not help the nozzle check pattern to print completely, your printer may require service and you should contact the EPSON Connection for further assistance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 08, 2011 | Epson Stylus 880 InkJet Color Printer
I have an epson NX400 inkjet printer, all ink cartridges are full and are installed correctly. When trying to print, the black ink is not being printed. I have tried doing several head cleanings,...
hey friend,
This should be the problem of print head ink nozzle block.The nozzle for the black ink cartridge got dry.So the ink getsdried state.It won't allow any inks passing through the micro nozzles.Head cleaning won't help with the heavy nozzle block.So try replacing a new black cartridge or else bring the printer to the nearest service center.It'll help so.
Mar 06, 2011 | Epson Stylus NX400 InkJet Printer
My back ink is not printing on cannon mx700 all in one eventhough I changed a new black ink
You may have to clean the print nozzles.
Print a Nozzle Check Pattern
  1. Confirm that the printer is connected to the computer and the printer is turned on.
  2. Complete or cancel any print jobs in progress.
  3. Open the Printers folder.
  4. Right-click the printer icon and select 'Properties'.
  5. Click the Maintenance tab. (The Maintenance window opens.)
    Note: The layout varies depending on the printer and version of Windows you are using.
  6. Insert a piece of letter-sized plain paper in the paper tray.
  7. Verify the desired paper source for the Nozzle Check is selected on the unit by changing the <Paper Feed Switch> if necessary.
  8. Select 'Nozzle Check'.
    Memo: By clicking 'Initial Check Items' before clicking 'Print Check Pattern', you can see the specific confirmation items in Nozzle Check.
  9. When the confirming message is displayed, click 'OK'. (Nozzle Check printing will start.)
  10. Examine the Nozzle Check output.
  11. Determine whether the pattern is normal or not normal.
  • Click here if the pattern is normal.
  • If the pattern is not normal, perform a Cleaning.
    Note: Perform this step first to clean the print head.
  • If the pattern is not normal after two Cleanings, perform up to two Deep Cleanings of the print head.
    Caution: Cleaning consumes a certain amount of ink. Perform cleanings only when necessary.
If this doesn't work, go to the same maintence menu and pick nozzle cleaner and then try again
Feb 28, 2011 | Canon MX700 Office All-In-One InkJet...
Despite cleaning ink head many times, the yellow cartridge seems blocked as colour not showing
You will have to clean the print head, not just the ink cartridges. Here's how to clear blocked print heads:
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-if no luck, you may want to dip the print head into Isopropyl Alcohol overnight (can get it from chemist)
-if it still doesn't work, your print head may be clogged to the point where it needs repair or replacement, which will probably cost more than a new printer.
Nov 30, 2010 | Office Equipment & Supplies
Photos printed come out faint and lines andblack streaks across the photos how do i solve this/
lean The Print Head Nozzles (Windows) The following contains instructions to check the nozzles for poor print quality and perform cleanings of the print head nozzles as necessary. If print results are faint or streaks are printed, the print head nozzles may be clogged. Print quality can be improved by performing print head cleanings or print head deep cleanings. aution: Only used the approved methods below to clean the print head. Use of other methods may further clog the nozzles on the print head and may cause permanent damage the print head.
Note: It is important to check the cleaning results by printing Nozzle Check Pattern after each cleaning. Cleaning and Deep Cleaning consumes a certain amount of ink. Only perform a cleanings when necessary.
  4. Click the Maintenance tab. (The Maintenance window opens.)
  5. Insert a piece of letter-sized plain paper in the paper tray.
  6. Verify the desired paper source for the Nozzle Check is selected on the unit by changing the Paper Feed Switch if necessary.
  7. Select 'Nozzle Check'.
Aug 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Poor color
try to put your cartridges with warm water
Sep 13, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Vertical lines throughout photos
Solution: Clean The Print Head Nozzles (Windows) MP500 / MP800
lean The Print Head Nozzles (Windows) The following contains instructions to check the nozzles for poor print quality and perform cleanings of the print head nozzles as necessary. If print results are faint or streaks are printed, the print head nozzles may be clogged. Those phenomena can be improved by performing print head cleanings or print head deep cleanings. nozzlecheckflow_en.jpg
Dec 19, 2007 | Canon Pixma MP500 All-In-One InkJet...
Epson PictureMate C11C623001 Photo Printer Logo
1,145 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
