Question about Canon Cameras
Camera will not take pictures I keep getting an error
Cmera is giving me an err cf and it is not the card
  • 2 more comments
  • Voicepower Apr 01, 2008
    I also keep getting ERR CF even though battery is freshly charged and card is new.
  • wittap Jun 07, 2008
    Same problem, Camera says CF Full. Thought is was a camera problem, but somehow I actually had 3 full cards!!!
    Now to download them....
  • kgoulette Oct 27, 2008
    Similar problem with Rebel XT. Reformatted the CF card on the camera just prior to the event and installed a freshly charged battery. Had taken about 50 pics when I received the CF ERR. Could not take any more pics or review or download what I had taken. Immediately replaced the CF card with my spare and camera works fine. No problem downloading from the second CF. Appears my CF failed as the pins look fine and the second card works well. Any idea of why this would happen and can I salvage the pics on the first CF?
  • blinkutza Jan 05, 2009
    I actually have the same problem.
    after i replace the CF card with a new one .. i get "Err 99" and I still cannot take pictures .. I really don't know what to do now.
    please help!
Go to your computer, put the card and format but remember that the computer will erase all the pictures in it. Tat was the problem in mine card.
Posted on Sep 20, 2008
ERR CF and ERR 99
there is cf unit faulty might pins are bent or damage and could be come out from board that why giving cf error and err99
Jul 25, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Digital Rebel XTI 400D Displays Err 99. Problem with CF card. Replaced with brand new card-still same err 99 camera is totally charges, acts dead, keep flashing Err CF, I try to format, it...
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Aug 31, 2008 | Canon EOS-20D Body only Digital Camera
Get Err CF in view finder and cannot take pictures
did you try removing the memory card and making sure its not locked?
Mar 18, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
ERR 99
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I am getting an error cf..tried to format card and get error 99
I Googled the error code you're getting, and found a list of things to try and steps to attempt directly from Canon. Try out some of the stuff below, it should help.
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
Error 99 appears in pattern, every time
Not sure about the pattern of errors, but the advice for error 99 diagnosis is to try the following diagnosis steps to isolate the cause of the issue:-
Feb 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
My camera say err CF
These are steps to Fix Err 99's, have a go and see if resolves your other problem too.
Dec 28, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon 300d gives error 99 and does not work
Try the following diagnosis steps: -
Nov 28, 2008 | Canon Digital Rebel / EOS-300D Digital...
Camera won't turn on
Does the camera do this with any CF card? If you've tried another CF card with the same problem, check in the slot that the CF card fits into with a strong light to make sure no pins are bent and touching each other.
Also, was the card formatted with a Windows 2000 or Windows XP system? If you format with Windows, make sure you specify FAT32 as the file system (rather than NTFS).
Err 99 is a 'catch-all' error message that is non-specific. It indicates that the camera detects an error within its operating system, but cannot determine the specific reason.
In summary, try another card. If you get the same error, and no pins are bent, you probably need to have the camera serviced.
Aug 31, 2008 | Canon EOS-20D Digital Camera
Cameras Logo
467 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
