Question about Fujitsu FPCRC05 Remote Control
AR-RY7 Fahrenheit to Celsius
I also have an Fujitsu AR-RY7 remote that I would like to change to Celsius. I have read the replies posted here and tried solution #4 but it does not work for me. I have had the remote completely apart and can find no removable jumpers. The only jumper is labeled J4 on the circuit board and is accessible from the battery compartment without removing any screws but you need to cut it, it does not pull out. I tried cutting it (and ensured the ends were not touching afterward) but the only change is the wall unit will not respond to Start/Stop and remote still shows Fahrenheit. Is there some process that the remote needs to be put through after cutting J4 before the remote will show Celsius and work normally?
2 Suggested Answers
SOURCE: I have a remote control unit Model : AR-RY7
Jane,if you are still interested: Go to www.fujitsugeneral.com, click consumer, click service and parts, click manuals. Enter the model number of your indoor unit = small numbers on right hand side (e.g.,asu12rmlq and put plenty of paper in your printer. I had 19 sheets. Lots of luck. Bob
Posted on May 24, 2010
How to change from Fahrenheit to Celsius on new Fujitsu air con remote
After reading how it is done, you'll see why they don't put it in the user instructions, however, it is possible.
RC Fujitsu Inverter Air Conditioners Post 9 by
Jan 15, 2015 | Fujitsu Heating & Cooling
How do you change from Celsius to Fahrenheit on remote?
Go to settings/menu on the remote, find the Celsius/Fahrenheit mode, change it and done.
Sep 09, 2014 | HQRP Universal A/C Remote Control...
On the FAH125p2T the display is reading in celsius instead of fahrenheit
Good Afternoon Friend,
I understand you are trying to change the display from Celsius to Fahrenheit. To convert from one to the other and back, press and hold the " TEMP/TIMER" Up arrow and Down arrow buttons together for 3 seconds. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire Heating & Cooling
We have a Fujitsu split. remote ar-ry7 will turn on but unit doesnt respond. Read notes that say to reset remote. Dont know how. Wdereklewis@hotmail.com
If you look at the remote you will find a small pin hole you will have to use a pin to reset the remote just put the pin in small and push and that resets
Jun 01, 2014 | Heating & Cooling
Changing the external temperature gauge from Fahrenheit to Celsius
If your temperature reads in climate control reads in degrees Celsius "C" instead of Fahrenheit "F", follow these steps to change to Fahrenheit.
  • Turn the ignition on.
  • With the climate control turned on, push and hold the recirculation button in. While holding the button in, push and hold the off button in for 3 seconds or until you hear a beep.
The display should then change to "F". Follow these same steps to change your read-out to Celsius , if preferred.
Sep 21, 2012 | 2005 Land Rover LR3
I have a remote control unit Model : AR-RY7 fujitsu for a ductless airconditioner unit without a manual. I need to know how to program it.
Apr 02, 2010 | Fujitsu FPCRC05 Remote Control
How do you change the tempature reading for the air conditioner from Celsius to Farenheit?
You can switch the temperature mode between Fahrenheit to Celsius as follows:
While depressing the AUTO button, depress the OFF button for 3 seconds or more. The display will change from Fahrenheit to Celsius, or from Celsius to Fahrenheit.
Feb 03, 2010 | 2004 Kia Optima
Just do not understand it at all! can you help with model ar-ry7?
An inverter uses 12 volt DC current and inverts it to 110 volt AC current.
Basically, it will take 12 volts from a car battery, and change it to 110 volt current , same as in your house. What part are you having problems with?
Jan 03, 2010 | Fujitsu Electronics - Others
Ductless Air Heat remote
I have the same remote(and the same issue), for a Fujitsu ASU9RMLQ system. I just found the link to the manual for my system, it has some instructions on how to use this remote:
http://www.fujitsugeneral.com/PDF_06/OperationManual/(OM)AOU24-36RML.pdf
Jun 25, 2008 | Fujitsu FPCRC05 Remote Control
Fujitsu FPCRC05 Remote Control Logo
1,196 people viewed this question
Top Fujitsu Televison & Video Experts
Tony
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
