WD 500 My Book Prem Ed will not power up
Have a WD 500GB My Book Premium Edition Ext HD. After working fine for several months, I had problems with my Mac repeatedly not recognizing the WD. Now the WD will not power up when connected to wall outlet (no light and no sound). Should I buy another power cord before assuming the drive is not working? If it is the drive, any recommendations on data recovery services?
  • 339 Answers
If it's less than a year old, call WD and get a replacement power brick and see if that works.
You could of course also buy a replacement and see if that works.
If the unit is not powering up, the HD inside is almost certainly good. Data recovery is trivial. All you have to do is open the case(hard part) and remove the hard drive. Find a desktop you can install it into and copy the data to a new external HD. If you don't have a a desktop available, you can buy a USB to SATA adapter with a power adapter for about $15-20 that will work well. If you're creative you could probably re-install one of these kits into the existing enclosure for a permanent fix.
Posted on Jul 26, 2009
I have a WD 500Gb My Book that doesn't allow access to information. My laptop crashed so I reformatted it and reloaded it. The My Book holding all my backed up information shows up as connected as a...
the computer for some reason is not fully detecting the ext drive if its usb then try other usb connections. if it has sata hook up try using that there a much better connection but dont worry i think youl find that all your information is still on the ext drive thats why we should all use external drives for all our important photos music and files because when the pc blows or crashes then the other drive is not affected
p.s if the ext drive can with a driver disc try reinstalling it.
good luck
Jul 12, 2010 | Western Digital My Book Premium ES...
External Harddrive locks up Windows Vista Home Basic on start up
I would suggest two things.
First, plug in the 1TB drive when it won't cause problems, and go to Disk Management under Administrative Tools (for example right-click the My Computer icon and select Manage, then drill down to Disk Management). Check your 1TB disk's drive letter there, and perhaps change it to some letter further down the alphabet, like "T" for example.
Then run a full check on the drive - right-click the 1TB drive and select Properties, go to Tools tab and run "check for errors", selecting the option to repair system errors.
After that's finished, plug in the 500GB drive and run a full check on it as well, just to make sure.
Now try booting up with both disks plugged in - the problem should be gone.
If it's not, then it may mean, that your BIOS is trying to open this 1TB drive to make an option to boot from it possible, and it has troubles because of it's size; some older BIOSes can't cope with disks of that size. Should this be the case, you can go into BIOS Setup and disable booting from other devices that the primary internal hard disk.
A
Jan 02, 2010 | Western Digital My Book Essential Edition...
WD My Book Studio Ed. (Mac) - 2TB - stopped working for no reason
plug your drive in to your computer, right click
on my computer and bring up disk manager,
open disk manager and see if your wd drive
shows up. then reinitialize the drive and this
will hopefully solve your problem.
Aug 21, 2009 | Western Digital My Book Home Edition 500...
My network wont detect wd my book world edition 500 GB HD
if u have a Cd rom which have a driver then u shoud download it on all computers in ur network to make it work better and faster but if there is no CD driver then u shoud read its manual
Jul 25, 2009 | Western Digital 500GB My Book World...
WD 500gb external HD shuts down when plugged into USB port
Try a replacement USB cable first. If that does not fix the problem, then the USB to SATA adapter board is faulty, in that case you will need to take out the internal disk to replace the external enclosure.
see
YouTube - How To: Take Apart A Western Digital My Book Enclosure
If unit is under warranty see : WD Support > Warranty Services > End User > Warranty Policy.
Note any SATA external enclosure willl work wthe same with the internal WD HD.
Apr 17, 2009 | Western Digital My Book Home Edition 500...
Wd my book broken!!!
Hi naths99,
Not to worry, you haven't lost the drive, what you have done thou is you formatted over all the software that allowed the drive to mirror your data. But as I said all is not lost. Here's a link that will reinstall all the software that was originally there. HERE! Pick your My Book and away you go!
Good Luck
Mark
Jan 02, 2009 | Western Digital My Book Premium ES...
WD My Book 500g HD error. Turns off when USB is plugged in
Check the USB port on your computer. It's very likely that the problem is there. On my computer USB ports stop working sometimes and the HD does exactly that. HOwever, when i restart the computer, everything works fine.
Mar 30, 2008 | Western Digital My Book Premium ES...
WD, my book hard drive NOT WORKING ANYMORE!??
It sounds like it's failed, and needs to be replaced, WD will ship you a new one if you give them a credit card, then you can send that one back, don't forget to send it back though, or they'll charge you several times what you could buy a new one for at your local shop.
Oct 15, 2007 | Western Digital My Book Essential Edition...
Computers & Internet Logo
200 people viewed this question
David Payne
David Payne
