Question about Honda Maxus Pressure Washer MX5222
Pressure washer won't pull the from the soap dispenser
There doesn't appear to be any soap moving through the tube. Used to work, but doesn't seem to anymore. Any thoughts??
    Sergeant:
  • 384 Answers
Nozzle dirty, clean out nozzle with small diameter wire. Soap dispensing only happen at nozzle low pressure setting
Posted on Jul 27, 2009
Why won't It siphon soap?
These units use a venturi to inject soap, where the tube goes onto the brass barb, that should unscrew and there is a little ball bearing and spring in there that sometimes stick when thay have not been used for a little while, if you clean the ball bearing up with some steel wool and lube it up and reassemble, 9 times out of 10 this will rectify your problem
Hope this helps,
Brad
Jul 29, 2014 | Dewalt DPH3100 Gas Pressure Washer
It is only one year old and only been used last summer when i got it out this spring the detergent will not dispense
take off clear tube that goes into solution jug(where soap goes),make sure it is clear(water passes thru it easily) use a soda bottle- fill with vinegar- reattach hose and put other end in soda bottle- if this doesn't work that valve in the sprayer itself is gummed up- sometimes using HOT water feed sprayer will clear an internal plug
May 10, 2011 | Briggs & Stratton Prosumer 20324 Gas...
Can't get soap to feed into system
I have a SIMONIZ S2000 electric. I bought the unit about 8 weeks ago used it once. On the second use yesterday the unit didn't work as well, the pressure seemed only a bit better than hose pressure and soap did not dispense at any pressure. SO.... after much thought I turned the hose/tap pressure down so that I only got about 2-3 GPM instead of the typical 5-6GPM normally coming out of my hose....... it worked! Soap dispenses and spay is way better! It seems that if if the inlet hose pressure is high the pump doesn't work as well... go figure.
Jul 04, 2010 | McCulloch FHH18A Electric Pressure Washer
No high pressure water
Jul 01, 2010 | Karcher 1550PSI Pressure Washer
Solutions won't feed from bottles on machine? I use the switch on this machine to use a deck cleaning solution and the bottles won't feed the solution into the water.
Jun 25, 2010 | Campbell Hausfeld 1800 PSI Electric...
Pressur not costant
Jun 21, 2010 | Karcher K2.26 Electric Power Washer
Water is coming out of the soap dispenser, what do
We had water pour out of the dispenser of our Kenmore HE2 washer. hot water helped us for one load then i realize that a trapped rag was the problem We were actually able to pull the face cloth out of the intake tube without taking everything apart!
opened the washer door and feel around inside the rubber seals to find where the intake tube connects to the drum (upper-left side). felt a small bit of cloth sticking out of the tube and were able to slowly work it out by pulling back and forth. and pulled it completely out thats all it was try this
Oct 05, 2009 | Kenmore HE2 Plus Front Load Washer
Wont pull detergent
problem is that u have to use with lowest pressure i believe black tip
Jun 20, 2009 | Honda Maxus Pressure Washer MX5222
No pressure on simoniz gas pressure washer
May 03, 2009 | Garden
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Honda Maxus Pressure Washer MX5222 Logo
4,971 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
