Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Overheats & spits sparks The problem began with overheating with no more compression build up after about sixty pounds . The oil was visible in the sight glass and it was clear . I then changed the oil anyway . I began using the compressor again but the problem got worse . Sparks began spiting out and the oil turned black . How bad is this thing anyway . Replace ?? Repair ?? ACM
    President:
  • 1,922 Answers
If its integrated, hooked together,no belt(comp and mtr) its time to save air tank and buy a new one,saving the air tank only gives you more capacity if plumbed to new unit
Posted on Jul 28, 2009
My briggs and Stratton Intel 206, 5.5 hsp, was running fine, began to lower rpm until finally quit, oil and gas ok, cleaned jets, no change? Could it be a governor or linkage issue.
I would check Spark & Compression with Compression tester! This goes into the same place where the spark is& Compression should be above 70 if not the engine is no good. Let me know.
May 15, 2016 | Garden
My 97 f250 overheated and wont start now, checked sparkplugs coil cylinders gas,fuelrail pressure, inertia switch,fuses that i can see etc.
If it overheated you may need to do a compression test and cooling system pressure test to determine if you have done serious internal damage.
Feb 28, 2015 | Ford F-250 Cars & Trucks
Car overheated today and began to spill oil. now that I've put water and new oil it doesn't leak but the car shakes when I put it in drive
have you checked the compression on all cylinders?;if two adjacent cylinders are in low range,you may have head gasket damaged. Did you notice oil mixed with vapor on the radiatior cap,oil in the radiator/crankcase (oil looks like chocolate color 'cause of oil/water mixed). Do your spark plugs look like they've been steam cleaned?(from steam in the cylinder head)
Aug 03, 2013 | 1996 Jeep Grand Cherokee
Overheats intermittenly
Lets use common seen here
Any overheating at all,even one time,you stop
using the vehicle until it is diagnosed & all of the
vehicles issues including preventative maintenance
are caught up on
If you have any overheating, you will damage the engine &
possibly other components, if not already done
Jun 09, 2012 | 2002 Kia Sportage
I have a 98 DeVille and it's overheating with some moisture coming out the tail pipe, but no oil and water mixture. There is no visual leaks at the moment. I just bought the car and test drove the
For car running hot and overheating issues, I suggest to you go through this help links.
Click this link below and go through the troubleshooting procedure to take care of the problems: ----
Car runs hot?
http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?
http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
overheating?
http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Feb 03, 2012 | 1998 Cadillac DeVille
I have a 2001 ford taurus ses with a 6 cyl 3.0L DOHC engine. Getting error codes P0304,P0305 and P0306 from check engine light. Light alternates between flashing and steady. Lots of hesitation and...
Codes say Cylinder 4, 5 & 6 are not firing. This could be a spark issue or a fuel issue or a mechanical engine failure. Is compression zero? Did they use a compression tester?
Aug 02, 2011 | 2009 Ford F-150
Hero honda splendor is my bike it has problem of oil is coming in spark plug & spark plug is short how can solve this problem
The Honda Splendor has a 4 stroke engine and can have worn valve seals or rings. If the engine smokes while riding it may be time for a top end re-build. You should complete a compression test to evaluate the condition of the piston and valves. If the compression is low ( under 120 psi ) it is time for a top end re-build.
Steve
Jan 02, 2011 | 2006 Hero Honda Splendor+
2004 v twin 16 hp 500hours on it runs but spits fuel throught carb when giving gas runs like its missing on one cylinder replaced carb, plugs, fuel filter, it has 120 lbs of compression in each cylinder...
You should take one of the heads off and look at the valves. You may have deposits building up no the valves.
120 pounds compression sounds pretty good for a six year old engine with 500 hours on it. It probably started life at 9 to 1 and now is around 8 to 1.
May 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
350 chevy Lost compression and engine began to smoke.
pull out your spark plugs and try cranking the motor again, see if you're spitting out coolant from the plug holes. I'm asking you to do this, cuz it sounds like you blew a head gasket.
Mar 02, 2009 | 2000 Chevrolet Blazer
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
173 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
