Question about Lands Phones
I'm not able to send or recieve faxes on my panasonic KXFP105, Do I need a phone line going into the unit? If so how do I do this to work with my home landline?
    Sergeant:
  • 277 Answers
Well come, all you need to is to try and replace the fax message server settings back
Posted on Jul 26, 2009
8860 wont send or recieve fax on cable modem
Fax machines usually only work over regular phone lines, not through digital cable or DSL systems. If your phone is a VOIP phone, it is a digital system and your fax will not work. It needs to be plugged into the Plain Old Telephone System (POTS) which is an analog system.
May 05, 2012 | Xerox Office Equipment & Supplies
It will send faxes but not recieve them. it is on
Be sure the fax is on the proper phone line. You can send on any line but you can only recieve on the line for your number.
DickyO
Sep 01, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Unable to send/recieve with my Samsung SF 565P fax
Plug a phone in to fax port, Is there a dial tone there also? can you dial a number and make a call from the fax port? You should be able to with a regular phone. If you can't, try plugging in the fax machine to the other port where your phone is plugged in. try sending a fax.If it works there, then the Vonage device or your service itself is the problem.
Apr 22, 2009 | Samsung SF-565P All-In-One Laser Printer
Cant send faxes or recieve
Do you still have the problem?
Did you go through the entire setup procedure according to the manual including the fax/tel set up? Fax/tel setup tells the fax machine how you are using it. For example is the phone line used for just receiving faxes or is it used to receive phone calls AND receive incoming faxes OR is there a telephone answering device (TAD) attached to your phone line. If there is one, set it to 2 rigns. If you have it set to 4 rings the fax could disconnect before receiving the incoming fax. If you cannot send, then it has to be a line problem assuming you went through all the set up procedures correctly. Short of this you may have a bad unit and need to return it.
Apr 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
Panasonic KX F511 wont' send or receive
If you cannot send or recieve. First make sure you have a dial tone at the jacj in the wall if you cannot hear it on the handset of the fax plug a phone into it and make sure.
Second make sure you have the line from the wall plugged into the jack on th machine that says LINE. Most machines have three jacks Phone handset and LINE Make sure you are in the LINE jack.
Hope this helps
Feb 18, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Can't receive faxes but can send them okay
The easiest thing to check is the recieve mode setting. most of the time when this happens the machine is set on manual recieve. Set it to automatic recieve and you should be fine.
Oct 29, 2008 | Brother IntelliFAX 4100 Laser Fax
Fax wont send
try sending to another machine and also from a different telephone line if possible.Also does this machine receive a fax.Noise on telephone line can cause such problems.
Feb 27, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Can't send any faxes
Hello,Mafriend,It sounds like you might have recieved a Fax machine that Recieved a surge,To verify this Ck the Jack where the Phone line goes in to see if you have any type of discoloration there,also see if it locks up your phone line from making calls or recieving Them ttech
Jul 20, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
Lands Phones Logo
47 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
