Question about Maytag Atlantis MDG7400AW Gas Dryer
My Maytag Atlantis Gas Dryer makes a loud noise when it is running. It works fine except for the noise. I have had the dryer about 5 yrs and this noise just started several days ago.
My problem was a screw was stuck between the tub and the stationary housing. By simply running your hand along the edge of the tub, you may find something there gausing the grinding noise. Gerard
Posted on Aug 29, 2009
    Scholar:
  • 84 Answers
Is it a high pitch noise. Like a noise that sounds similar to a old freddy cruger movie when the little girl on the tricycle passing by. If it sounds like that, then maybe you idler pully needs to be oiled..the idler pully is what keeps tension on the belt and lets the belt rotate smoothly. just like a pully. That maybe needs to be oiled..try doing that and see that works.
Posted on Jul 27, 2009
I have a Maytag Performa dryer about 5 yrs old. It wont start anymore but makes a humming noise instead.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 15, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
My Maytag Neptune dryer, works fine until the last 5 to 10 minutes and then starts to make a loud skreeching noise. Suggestions??
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 18, 2011 | Maytag Neptune MDG9700A Gas Dryer
My dryer is making a very loud noise. it is still drying and turning. what could this be?
heatman101
Mar 15, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Mar 02, 2011 | Maytag Dryers
My Maytag Atlantis gas dryer is making a sqeeling noise and sometimes will not turn the drum, unless i hand turn it and my run, i open it up but nothing looks out of order, the motor smells as if it is...
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 24, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer noise
A drum support wheel bearing could need lubrication or be replaced.  Also some drum support wheels have a rubber coating that wears off causing misalignment and noise.  Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced.
Jun 02, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Dryer
hi thanks for the question i would check the venting on this dryer make sure its clean if you can vacuum the entire dryer this will solve your problem thanks the appliance doc
Aug 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
307 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
