Question about Car Audio & Video
Installed an 86 EL-Camino steering column with new wiper switch, in a 79 El-Camino and unable to get the wiper motor to work right. Need wiring diagram for 86 EL-Camino wiper diagram to cross reference with 79 EL-Camino I am restoring .
  • onecoolgrizz Jul 26, 2009
    I like to know how I can get my new 86 El-Camino wiper switch on steering column to work on a 79 EL-Camino, is the color code different in the years for the wiper motor. IF so what. Match the colors and doesn't work well.
  • onecoolgrizz Jul 27, 2009
    No! The books does not show which color code wiring or to which wire is the hi or lo speed on the wiper and so forth
  • 601 Answers
Hi....
I dont have one but you can pick up a Haynes manual on it at like Auto Zone and it has wiring diagrams in the back. Shows color codes on wires and where they run.
Hope this helps
Thanks
Smith
Posted on Jul 26, 2009
I put a new wiper motor on a 79 el camino and it works but it dont move the wipers it just turns and i got the 2 nuts tite on the wiper transmission
Check to make sure that the "Knurled" segments on the tapered points that hold the wiper arms to the motor actuators are not worn smooth as this is what gives the actual grip required for the wiper movement. If they are worn smooth then no amount of tightening will help.
Apr 07, 2017 | Chevrolet El Camino Cars & Trucks
I have 79 El Camino. Horn blows randomly while driving down the street. How do disconnect ot
You can unplug the horn/s. You could pull the horn fuse, pull the horn relay. Of course that isn't the proper fix, you may need the horn. The problem is usually the wiring in the steering column. I can't be positive, at the moment.
Jul 22, 2015 | Cars & Trucks
How to remove ignition switch from 1977 chev el camini tilt column
Pull the steering wheel, get the push down tool to push down the lock plate to remove the plate, then pull the turn signal cam theres a screw on the right hand side of the shaft that holds the cylinder in.
Jul 23, 2010 | 1982 Chevrolet El Camino
Need to open up the steering column on 1983 El Camino for igniti
Saw, It sounds like the accuator rod from the ignition lock cylinder to the ignition switch is broken or disconnected.
If you look near the base of the steering column you wll see the ignition switch mounted to the steering column. As you turn the key you should see the rod move up and down, if not, you will have to disassemble to figure out why.
Good luck, let me know what you find.
Regards,
Feb 24, 2009 | 1983 Chevrolet El Camino
Hi low hiead light switch 82 el camino wher does the rod hook up
should be a switch mounted to the top lower steering column that the rod fits into that operates the high/low beams
Dec 28, 2008 | 1982 Chevrolet El Camino
Ignition Switch
Hello 85chevy,
Thankyou for choosing FixYa.com my name is David this should help you with your problem
Home > Product and How-To Information > Product and How-To Information: I > Product
Ignition Switch grey_line.gif Inspect | Test | Replace The ignition switch is usually mounted to the steering column and is operated by a linkage rod.
NOTE On column-mounted ignition switches, don't confuse the switch with the lock cylinder and keys. The ignition switch is not normally visible.
On some vehicles, the steering column support has to be removed and the column lowered to find the ignition switch. On others, the switch is accessible under the dash.
The ignition switch is operated by the key switch. Courtesy of Ford Motor Company.
To replace the switch:
  • Remove the ignition switch wiring harness.
  • Unbolt it from its position.
  • Bolt the new switch into position.
  • Attach the witing harness.
upper_left.gif grey_line.gif upper_right.gif grey_line.gif Look for More Parts A B C D E F G H I
J K L M N O P Q R
S T U V W X Y Z grey_line.gif lower_left.gif grey_line.gif lower_right.gif Related Parts: grey_line.gif 0900823d8004b202.gif Lock - Ignition (Cylinder and Keys) Return to top.
Nov 06, 2008 | 1985 Chevrolet El Camino
Does anyone have a wiring diagram for an 86 El camino
You can pick up a Haynes manual on it at like Auto Zone and it has wiring diagrams in the back. Shows color codes on wires and where they run. Hope this helps
Oct 03, 2008 | 1986 Chevrolet El Camino
Giovanni
I have a 1983 Royal Knight SS. Had the same problem. Had my wiper motor and washer pump replaced. works like a dream now. replaced my original combination turn signal wiper switch on steering column and now have good working intermittent wipers. It is great to see driving in the rain now. Jackson  in ATL
Oct 01, 2008 | 1983 Chevrolet El Camino
Car Audio & Video Logo
142 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
