Question about Maytag Neptune FAV6800AW Top Load Washer
Neptune Washer with lid signal "od"
I would like to thank everyone in the discussion on lid lock problems with either "od" or "OP" signals of their machine that prevents the use of their Neptune washer model FAV6800 models. The left lock latch under the top portion (not the lid). I used a flat headed screw driver to pop the top portion. The left side locking latch is simply not sealed. Water or moisture or humidity easily oxyidize or corrode the terminal connections inside the white plastic holding box container. I simply used some lightly graded sandpaper to gently sand away the damaged or corroded terminals and used WD-40 after sanding. Take care that you reassemble the latch connector assembly insuring that the actual latches are in the unlocked position. Additionally, you may want to apply a little pressure on the lid in its down position to insure that when you turn on the washer to a cleaning cycle that there is properly clearance for the gray plastic latches engage to their locked position when you hit the "start" button. Cleaning the left latch is a MUST over the life time of your machine. Until Maytag can offer some kind of solution to its corrision problems with these locking latches, users will face "od" or "OP" errors on their display with this washer.
  • dh1200s
    dh1200s May 11, 2010
    Can't add a comment so just passing along this, this not a clarification request. Thank you oak9952, great info! Here is pic of what you probably experienced. Some folks have had issues with the leads on the magnetic reed relay in that left lid lock, the corrosion issue in full force. Just trip back the wire a bit and re-solder and you can be back in business. Pic of the corrision issue; very poor design as oak9952 stated and has caused many folks unnecessary grief and expense. Just to let everyone know the right lid lock can fail and it's not necessary to replace. The left lid lock with its dual function of lid open/closed signal and lid lock signal to the control board is the important one. Lead on mag switch broken do to corrision issue;
  • 335 Answers
OK this board won't let me post pics so I'll post as a solution, please everyone you don't need to rate.
Lead on mag switch needs to be re-soldered.
Posted on Jul 26, 2009
  • dh1200s
    dh1200s Jul 26, 2009
    Sorry oak9952
    I blew away your SM link here it is Service Manual. I think you had an additional. I did not know this board would blow away your links with my solution pic's.
    Rich
Washer will not start , od code is showing on the panel
You have lost signaling from the Left Hand Lid lock.
The OD code is sent out from the Console main control board when a lid open is not sensed via the signaling from the Left Hand Lid lock for three completed wash cycles.
Google this sticky for help with your issue ""Neptune TL Washer FAV6800AWW"" start at the 5th post down. You will find a link to the service manual and help on troubleshooting your issue.
Sep 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have an OP message on my Maytag washer FAV6800A/FAV9800A . The washer is not locked I can open the lead ...when I close the lid and start the washer the OP error comes up. Any help will be...
If you get no help at this forum Google This ""Neptune TL Washer FAV6800AWW""
5th post down you will find the SM and support for the "OP" error code. You have lost signaling thru the Left Hand Lid Lock............DH1200s
Aug 21, 2011 | Maytag Neptune FAV6800AW Top Load Washer
It says lid is open but its not
You have lost signaling thru the lefthand lid lock
Google this "Sticky: Neptune TL Washer FAV6800AWW"
Go to the 5 post in the sticky for the Service Manual and within the Sticky I describe the issue of OP, OD, and FL error codes.
Ypu don't mention in your description but I assume your machine is throwing an OP or DO error code.
I describe how to diagnosis and repair the issue.
Jan 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Display shows OP but unable to clear , checked out switch, 1 contact pin was heavily corroded. I polished it up but made no difference
If you place a magnet over the left hand grey bumper will this clear the OP error code with the washer lid up? If so you have a lid magnet out of position.
See page 35 of the FAV6800A/FAV9800A Service Manual for the location.
Did you remove the left hand lid lock cover and inspect the connections on the magnetic reed relay?
Check to see if the leads on the magnetic reed relay are connected. This pic shows the black lead broken from one end of the magnetic reed relay. This will produce loss of signaling to the Control Board and generate an OP error code.
See this link for Left Hand Lid Lock troubleshooting http://www.fixya.com/support/t3124779-od_alarm_neptune_tl
I discuss troubleshooting for the OD error code. You troubleshoot the OP error code in a similar fashion.
Rich
Jul 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
MY MAYTAG NEPTUNE MODEL FAV6800AWQ KEEPS DISPLAYING THE LETTERS OP
You have lost signaling thru the Left Hand lid Lock. The washer has not see the lid go closed thru the signaling with the magnetic reed relay in the Left Hand Lid Lock.
You could have a Lid Magnet out of position or severe corrosion. You can place a large magnet over the Left bumper like this and see if the OP error code clears;
See this post for troubleshooting the OP error code Left Hand Lid Lock Troubleshooting I go over OD error code troubleshooting but you troubleshoot the issue the same way for the OP error code.
If the Lid Magnet is not out of position you may have an open circuit thru the Magnetic Reed Relay as shown in the Pics of this link Left Hand Lid Lock Troubleshooting.
The p/n for the Left Hand Lid Lock is 25001048
Some other handy links. The Service Manual for reference. Sears Parts Direct for reference..........Rich
Jun 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Why does it say "op" when i press the start button?
I feel you have lost signaling from the Left Hand Lid Lock for Lid is Open/ Lid is Closed.
First check is to place a magnet over the Left Hand grey bumper and while watching the LED display see if the OP error code clears. If it does you have a lid magnet out of position. See the Service Manual for access to the Lid Magnet.
See Pic;
If an external magnet over the Left Hand grey bumper doesn’t clear the OP error code with the lid open then See this Link for troubleshooting Left Hand Lid Lock Troubleshooting. I discuss the OD error code but the OP error code troubleshooting is very similar. If the lid Magnet is not out of position then I feel you have a broken lead at the Magnetic Reed relay or severe corrosion issues with the Left Hand Lid Lock preventing Lid Open/Lid Closed status signaling to the Control Board in the Console.
FAV6800A/FAV9800A replacement Left Hand Washing Machine Lid Lock - 25001048
Let me know if you have any questions or concerns…….Rich
May 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Op code with the lid closed
Greg,
See this link for OD troubleshooting. If you have questions post back and I will help you….Rich
Some handy links for your machine FAV6800A or FAV9800A correct?
Apr 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune top loader model fav6800aww has an error code od
rlbishop720,
See this post Left Hand Lid Lock Troubleshooting . I discuss Left Hand Lid Lock troubleshooting for error codes OD,OP FL, FO all related to Left Hand Lid Lock issues. I also provide a link to purchase a replacement Left Hand Lid Lock if you don’t want to deal with a DIY fix.
Let me know if I can help…..Rich
Mar 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl washer lock not working my husband bought it used so I have no manuals I was able to run a load blaech water to clean it but now it just keeps flashing "od" I've left it...
If you are still having issues; The OD alarm is signaled by the control board when it has not see a lid open signal from the left lid lock for three completed wash cycles. Issue could be a lid magnet out of position or corrosion issues with the left lid lock and or plug connecting to the left lid lock. Take a look at his post. It’s for OP alarm issues associated with the left lid lock but it will give you a start point for troubleshooting. Post back if you have questions. Links for the the SM and parts for the Left Hand Lid Lock replacement info are in that post.
May 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Will not start up and show code 0d
Hello kc59mail ,
For the FAV6800A the od alarm means the Control Board has not seen a lid open condition for three complete wash cycles. I suspect the left lid lock.
I think you have a problem with the magnetic reed relay in the left lid lock. If you could try this? I want to make sure you signal an “OP” alarm to the display. Can you select Spin Only cycle with the lid open press start. Do you signal the “OP” alarm lid open to the display? If it does close the lid and the “OP” alarm should clear does it? I’m checking that the lid magnet is in place and the signaling connections are working thru the left lid lock back to the control board.
Let us know what you fin and we will go from there. You could try powering down the machine by removing the 120VAC power cord from you wall receptacle. That may give you three more wash cycles before the od alarm is triggered again.
Mar 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
314 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
