Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Replace mower belt - Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
  • 636 Answers
Try this site , it is called manuals online, you can down manual for free. Good to have on hand, Hope this helps you out.
Posted on Jul 26, 2009
How do i replace v belt on ltx 1040 cub cadet.
Nolan, Check the attached links,instruction and guides for belt replacement on Cub Cadet. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change the Deck Belt on Cub Cadet Riding Lawn Mower Using Model...
How To Install or Replace Drive Belt on Lawn Mower Cub Cadet
How to Change the PTO Belt on Cub Cadet Riding Lawn Mower
cub cadet belt replacement diagram Google Search
Jun 30, 2016 | Garden
Need diagram to replace belt on cub cadet mower
Hi there r photos on how to fit the belt. Type in Google. cub cadet mower photo of belt. There r also movies on YouTube how to fit belt. Type in how to change the PTO belt on ? cub cadet , good luck
Apr 20, 2016 | Cub Cadet Street Sign- tractor lawn riding...
Belt change 1972 craftman rider mower
Dan, Mower deck belt diagram /replacement links below. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Mower Deck Belt Diagram DIY
Riding Mower and Garden Tractor Belt Routing Diagrams
deck belt diagram craftsman riding mower Google Search
Apr 10, 2016 | Craftsman Garden
How to tighten drive belt on 26 inch walk behind mower or replace drive belt
Here is a video about how to replace the drive belt on a walk behind mower, hope it helps you out!
How to Replace Lawn Mowers Drive Belt
Jul 28, 2015 | Garden
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Replaced drivebelt on troybilt riding mower now the forward pedal moves mower in reverse?
Sounds like you have the belt running in the opposite direction. You need to Change the way the belt is routed around the pulleys
Jun 18, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
How to replace a belt on my 52
Put the lawn mower on blocks, look for a pulley or guard that retains the belt, remove it, remove the old belt, install the new belt, install the part you removed to get the belt off, done.
Apr 21, 2012 | Garden
Every time I lower my mower board my mower stops or slows down. I just replaced the mandrel and also the belt. When my mower board is raised up all the way the mower works good.
Lower the deck without it running and see if anything is making contact with the mower belt that shouldn't be. Sure sounds to me like you have the belt in a bind when you lower the deck, possibly by not routing the belt in the correct position when you replaced the belt.
Aug 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I am trying to replace my mower deck belt. I
got to www.searspartsdirect.com eneter model # for the tractor & it should give you the option to look at & the chassis & deck to help route the belt or give you the right belt part #
Jun 05, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
182 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
