Question about Polaroid FLM-3734B 37 in. LCD HDTV
TV wont show picture but redlight and blue light come on.
Hello, I just got this tv a year ago, it just shut off one day, the redlight power comes on but nothing on the screen. Please helm me.
Go to youtube.com. search, Polaroid 37 lcd hd repair. Two or three vids on how to fix. Radio shack has 45 watt capacitators for about 4.70 for two. Easy fix or get someone to help.
Posted on Jul 30, 2009
Seiki TV no picture or sound
hi test the large diodes on the power board these can stop the led from firing up, thanks, ps send me a picture of the power board i'll show you the diodes
shaun
Jun 15, 2017 | Seiki Televison & Video
Sony trinitron tv
Hello!I bought 12 years ago a SONY TV KV-28FX60D with out any technical issue so far.The last couple of days I powered on and after five minutes it starts showing only half of the screen, losing the bottom half of the picture. what do you think it might be. Can you suggest a part to be replaced and if it is worth fixing, cost wise? Thanks KONSTANTINOS
Jan 02, 2014 | Televison & Video
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
Tv will not turn on i push power on button and blue lights click on an tv acts like it will come on but then tv shuts off and no picture appears
The blue light merely indicates power is getting to the TV. When you press the power on button, the defective power supply shuts the TV down immediately
Jan 06, 2013 | JVC LT42P789 42 in. LCD TV
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
Jul 03, 2010 | Toshiba TP55H60 55" Rear Projection...
WHEN I TURN ON MY L32 I GET NO PICTURE. I GET BLACK SCREEN THEN LOTS OF COLOR, REDS ,BLUE ,ALL COLORS IN DIFFERENT PATERNS THAT KEEP CHANGING. SOUND IS PERFECT AND I CAN CHANGE CHANNELS AND VOLUMEAND...
It sounds to me like it's stuck in service mode.There is a button combination with the remote to return it to normal. I would call Vizio support and they should be able to help you.
I think it's a combination like [volume -], [channel -] and power but I could be wrong.
Dec 19, 2009 | Vizio L32 32 in. LCD HDTV
TV Not turning on , but blue power light is on
look in the back, see if the lamp is actually lit. If it is probably not a tv problem. If you can pull up the menu then you probably are on the wrong input. Are the fans running when you turn it on? IF fans are running might be lamp, if nothing is seen through the back.
Apr 29, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitatchi tv problem
A fuse has probably blown inside the TV, I had something similar with a panasonic TV a number of years ago. Open the back up and use a continuity tester across your fuses till you find the right one...................dont forget to unplug it first !!
Dec 10, 2007 | Hitachi 42HDS69 42 in. Plasma Television
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Blue screen
It sounds like the high voltage distribution block but that is not the cause of your problems,the tuners you talk about are the picture tubes ,one for each color,the blue picture tube was arking and you got lucky and got 6 more months of use, it and might have corrected when you drop it but now is the red doing it and you need to do the same but it might not work this time,dont be surprise.Be carefull while trying things in the back,there are high voltages there and is not safe unless you are familiar with tv service.
Sep 19, 2006 | Sony KP-61V45 61" Rear Projection...
Polaroid FLM-3734B 37 in. LCD HDTV Logo
387 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
