Question about Bosch BSG71360UC Bagged Canister Vacuum
Bosch Formula vacuum cord stuck
I have a Bosch Formula vacuum and the power cord is stuck inside.
  • melodybob Jul 27, 2009
    How do you take apart the reel?
  • 38 Answers
You need to take apart the reel. The cord is wound over itself and kinked. Be careful taking apart because if it gets away from you, you will have to wind the spring by hand and it is difficult to do and frustrating.Good luck
Posted on Jul 26, 2009
  • 35 Answers
How u take apart this product. Any screws
Posted on Dec 28, 2009
No power, fuse has been checked.
possibly bad switch or cord wire pulled loose inside
Apr 16, 2015 | Bosch Vacuums
Bosch hygienixx formula bsg71266gb/07.Lost my manual and would like a copy. Also can't work out how to empty the bag.
Hi. Visit http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html and follow the link to add the model number in. Also if no joy there contact Bosch UK - they will be happy to help you. Generally this vacuum has a bin door at the top that opens up towards the owner. The hose will have to be removed and the latch is behind the handle. Thereafter the bag can be slipped out and replaced.
Oct 29, 2013 | Bosch Vacuums
I had my bosch 1400 W 12 amp vacuum plugged in and it blew a fuze so I reset the home fuze box and went to plug it in and it sparked and blew the fuze right away. The plug was very hot to touch. I am...
Often if the plug or cord is a problem, it can be seen. Look carefully at the plug, are the prongs straight? Is the cord damaged where it enters the plug? Is the cord damaged where it enters the vacuum? If the plug was rotated, it is possible that the wires inside the cord may have frayed insulation and are making contact with each other.
If it is the plug or the plug end of the cord, you can get a new plug at Home Depot and replace your old one.
Also, if you have a switched outlet or switched multi outlet extension, you can shut the power to the outlets off, plug in the vacuum and turn on the switch so you are not near the plug when you plug it in to test it.
Gary
Jun 23, 2011 | Bosch 12-Amp Formula Canister Vacuum with...
I have bosch forumla vaccum and cord got stuck. It is very hard for me to see the screws to open it. Could somebody help me how to open this safely.
This problem is solved easily after I found the third screw to open the top cover. You will find the third screw under the top cover where the variable regulator is. But be patience, your small mistake can screw up whole system. You will need a torx screw driver set.
Remember, dismental step by step. top cover/screw/top housing.
I found my cord retract mechanisam spring broken, I didn't put new one. Cause it could cost me more. However I just took the cable out which was tangles and kinked.
Dec 28, 2009 | Bosch BSG71360UC Bagged Canister Vacuum
H2O Vacuum Turbo, the cord was stuck. How to fix it? Thanks
The re-coiling mechanism could be stuck with dirt or out of alignment. You could turn it upside down and get a long screw-driver to remove the lower cover. You will have to trust your best knowledge/instinct to figure out what needs to straighten out.
Oct 31, 2009 | Bosch BSG71360UC Bagged Canister Vacuum
Vacuum will no longer turn on. Vacuum bag was
Same problem. I suppose BOSCH dumped these into the market and have chosen to disown them. Support is pitiful and vacuums have also been taken off their website. Too bad, was a nice quiet product for the 2 months it worked. Solution = new, non-BOSCH vacuum.
Oct 04, 2009 | Bosch 12-Amp Formula Canister Vacuum with...
Cord rewind nonoperational
sounds like the spring is either over stretched or broken. you may have to have the spring replaced
May 11, 2009 | Bosch BSG71360UC Bagged Canister Vacuum
Bosch cannister vac: Cord is stuck--won't rewind
It probably is, these cords are usually 15-25' long ;-)
What you can asssume is that the cord is simply twisted upon itself and doubled up so cannot easily come out, and will not go in... therefore.
Pull gently on the cord and twist in a clockwise direction. Does the cord seem to get a bit longer? If not, or if it gets tighter, try counterclockwise. If you keep trying eventually it will loosen and you can fully extend the cord. Compare this to holding a piece of string between your hands by the thumb and index fingers. Hold one end still and twist the other 20 times (twisting the string). then relax the string between your hands. See how it immediately forms a loop? That is the problem with your cordreel too. There is a loop in there that we need to undo. Now pull a bit so you can still see the loop, and then start untwisting to see what happens. You can also do this with a YoYo ;-)
Be patient, observe, sensitize your tactile senses and see if you can figure out which direction loosens your cord - and get it out ;-)
Good Luck
Hopefully you wont have to take it all apart. that cordreel spring is very strong. Be careful if you do go in there.
Mar 26, 2009 | Bosch BSG71360UC Bagged Canister Vacuum
Can't refit dustbag to bosch ergomaxx barrel cleaner
The bag slips into the holder which should be attached to the machine. If you have taken this out by mistake and thrown it you'll have to contact Bosch to order a new bag holder.
Jan 22, 2009 | Bosch 12-Amp Formula Canister Vacuum with...
Bosch BSG71360UC Bagged Canister Vacuum Logo
791 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
 John
John
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
