Question about Refrigerators
Hi, my frigidaire model frs26kr4a is only cold at the bottom half of the freezer and fridge. Any advice?
  • richard_fruc Jul 26, 2009
    Where are the air ducts? Where is the heating coil? I don't have a multimeter.
  • 10,865 Answers
Hello there. I can help you isolate your problem and hopefully even fix it. You need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on Jul 27, 2009
  • Refrigerators Master
  • 19,396 Answers
Check that the air ducts are not obstructed by dirt or ice. To this purpose it can be useful leaving the fridge to defrost completely overnight.
Also check that the defrost system is working. Ensure the defrost fan is running and that the heating coil is working.
The heating coil is tested checking continuity with multimeter. The fans can be tested energizing them directly. The defrost timer must also be tested.
If the air ducts and fan are fine, and defrost system is also OK, then check the fridge temp control pcb.
You find parts and diagrams for your appliance here.
Regards.
Posted on Jul 26, 2009
Ice maker not working on Frigidaire frs26kr4a
Good Morning Friend,
I understand that the ice maker is not working on your Frigidaire refrigerator, model# FRS26KR4A. First, make sure the wire signal arm is in the down or on position. Secondly, make sure your household water line is open. Thirdly, make sure your freezer is cold enough to keep items frozen. Fourthly, check the saddle valve, if there is one, to make sure it is not clogged or restricted by any foreign material. Lastly, Check to see if the water dispenser is dispensing water. If no water is being dispensed, the water filter could possibly be clogged and would need to be replaced. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire FRS26KR4A Side by Side...
My fridgedaire fridge FRT856embg wont get cold on the bottom
Im not familure with this item but on the older style fridge ice would build up in the freezer blocking the air ways to the bottom half of the fridge in this case you would need to remove the food from the freezer and fridge and unplug it open the doors and let it thaw out for a day or so I wish you luck and I hope this was helpful
Dec 07, 2012 | Frigidaire FRT21H8 Top Freezer...
Freezer keeps defrosting and nothing is stay frozen and nothing is staying cold in fridge either
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 20, 2010 | Frigidaire FRS26KR4A Side by Side...
I have a side by side gallery, The freezer and fridge are working at the bottom, however, not at the top of the unit. Its like the cool and cold air is not getting circulated to the top of the unit. From...
check the damper door vent as it sounds as if it has frozen itself shut or possibly the cold control in the refrigerator has gone bad and can't control the door,the door is usually behind a diverter panel or a grille where the fan forces the cold air in from the freezer,the cold control is the component that you adjust to change refrige temp setting
Mar 28, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire top/bottom fridge is on, but not cold in either the fridge or freezer.
We bought a small used Frigidaire refrigerator-freezer on top--Freezer is cold but items in frige are not...what could cause this
Feb 09, 2010 | Frigidaire Refrigerators
Top half of fridge and freezer are not working
I need that model number of the Frigidaire refrigerator so I will able to help you better. Thanks, Sea Breeze Here is my email should you not be able to contact me. seabreezehvac@yahoo.com
Apr 21, 2009 | Refrigerators
Bottom freezer not working
Hi, sorry I do not have any advice to offer. We have the same model. Three weeks ago the red light came on and freezer stopped working. Last week the fridge packed up. We may have been unlucky but I thought it might be worth mentioning incase they were related and your fridge gave up as well.
Jul 06, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Frigidaire frige not getting cold but freezer working
my refridgerator is not getting cold but the freezer seems to be working fine. can anybody please give me some advice on what this could be. We had a new defrost element put in a few weeks ago and we now have moved house so fridge is cool but not really cold enough model E402B any help would be appreciated.
thanks pam
Apr 29, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
