SOURCE: Will Not go to voice mail
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
SOURCE: Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
SOURCE: number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
SOURCE: NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
4.200
5.speaker
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
2.0:cancel
3.exit
4.exit
should see the normal display then.
SOURCE: phone won't ring
Check your call options to see if something called "Call Forward" is on. That might be your problem.
Hi Brendan Burt,
how many phones are connected to phone line ?
check all other phones are hung up and not still connected to phone line. ie in use
If there is a phone holding the phone connection the phone line will be timed out by the telephone exchange until all phones are hung up / not in use.
Could be one of your phones is faulty try isolating the other phones by removing them from the phone socket one by one to see if they are causing fault
