Question about GE Profile Harmony DPGT750EC Electric Dryer
Squeaky GE Dryer
The squeak has gotten very loud. Husband says if it is working he can stand the squeak sound. Is this sound due to something unsafe that can cause a fire etc. He tried to take the back off but it is like impossible to get it apart..We have a new baby coming home and I am scared if fire. Can you help me so I can pass this info to the hubby? Thanks so much.
    Sergeant:
  • 272 Answers
Greetings,
sight unseen, its hard to say exactly, but it is a place to start by looking at the belt pulley. these will make squeaking sound when bad or going bad..The drum rollers usually make a thumping sound, however, they can squeak too before failing..I would try and add a few drops of turbine oil to see if either get quiet..if so, replace when find which one is causing noise..Bruce
PS
its possible, the motor itself could cause this, but slim
Posted on Jul 26, 2009
  • 33 Answers
Hey bdenton1957, what they need to know is how to get it apart before they can do anything you suggested! I wish I knew how to take it apart, I have a blower problem.
Posted on Jul 29, 2009
  • Ed Paparo Aug 02, 2009
    PANELS
    take the top assembly off.
    that would be the display panel bezel, then the whole top.
    then remove the two top front screws and the screws inside the door.
    remove front panel.
    remove top inner panel, including the plastic strips, remove their screws and slide.
    DRUM
    remove belt from drum motor and pulley-take note how it goes back on!
    remove drum.
    before taking the drum out, remove the screws to the front drum panel and lift the panel up and out-AFTER undoing switch and light.
Squeaky GE Profile dryer model DPSE810EG5WT
There should be two wheels in the back that may have to be greased or replaced. There are two no friction pads that the drum rests on in the front that need to be replaced every once in a while. Go to searspartsdirect.com or appliancezone.com, with your dryer's serial number you should be able to find the parts.
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DPSE810EG5WT/0432/0151200?pathTaken=&prst=0&shdMod=DPSE810EG5WT
or
Appliance Parts and Accessories Repair Appliance Parts Discount Parts...
Feb 23, 2014 | GE Dryers
Indesit idv65 tumble dryer squeaking really loud
hi check drum bearing to see if worn
Jan 21, 2014 | Dryers
The dryer has a loud squeaky noise whenever I turn it on.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 29, 2010 | GE Profile DPSR475EW Dryer
Loud squeaking when you first turn on the dryer, it usually calms down after the dryer has gotten warm and the squeak is not so loud. Also tags from clothes are getting caught around the inside rim of the...
The problem is your bearing is nearing the end of its life. I just had mine apart and put a touch of axle grease on the drum main bearing, I also put a touch of this on the idler roller shaft (avoid getting any on the belt). Do not use petroleum jelly (Vaseline product) as it will turn into a liquid at the temperature the dryer runs at .
Dwight
Mar 31, 2010 | GE DBXR463EDWW Electric Dryer
My dryer is squeaky. it's a GE model number DVL223EYOWW. how do I fix a squeaky dryer?
It depends on what is making the squeaking noise. Could be drum bearing, drum slides, tensioner pulley, pr even the leveling legs sometimes squeak.
Jan 10, 2010 | GE Dryers
Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Sep 25, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer sounds like ''crickets''???
Replace the rear drum bearing, part number WE3X75.
Jun 07, 2009 | Dryers
Drum making intermittent sqeaky noise for 3-4 minutes then stops
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Squeaky dryer
Depends how technical you are. More than likely it is the rollers (depending on who made the Kenmore). Go to www.apwagner.com and you can get the parts there. Or if you are unsure about taking it all apart, call for service.
Sgt 48
May 03, 2008 | LG DLE2532W Electric Dryer
Squeaky dryer
This could be attributal to a dry spot in the idler pulley or 1 of the rear drum rollers.
Apr 15, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
491 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
