SOURCE: when i try to charge my battery the red light keeps flashing
Could be battery or charger. 1. Buy new battery. Still in trouble? 2. Get new charger Its good to have two batteries
SOURCE: My battery wont charge.
Hi I am Vortah The red light is usually an indicator that the battery is charged however in this instance as you are saying it isn't the battery has possibly gone short and you will need to replace the batteries . They have a type of internal memory and only charge a certain amount of times before they no longer accept charge and merely overheat during charging .. But I have to say it may be possible the charger is faulty as if the internal rectifier that charges the battery has gone short that may also bring the red light on in some chargers .. so try the battery or as I would do take it along to your nearest dealers and get them to check it . it may save you money in the long run you could be buying a battery you still cant use when you actually need a charger .. Hope this helps regards Vortash
SOURCE: env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars.
2. you can get a new phone. cost ???
3. you can get an external battery charger to charger battery separate from phone. cost about 25 dollars. check out the following link for ones that are available on ebay. LG VX9100 ENV2 External Battery Chargers
SOURCE: Battery not charging ?
Advise you to buy a new Digital
Camera Batteries for Canon PowerShot SD1100 IS
Replacement for: CANON NB-4L
,cheap and good performance.
SOURCE: My 24 v battery charger won't charge and the
You need a new charger. If batteries where bad charger would still light.
