Question about MotorGuide Electrical Supplies
Lost wing nut to mount - MotorGuide Electrical Supplies
    Sergeant:
  • 384 Answers
Buy at hardware store,
Posted on Jul 27, 2009
I am trying to replace aleft rear turn signal bulb on a 2005 lacrosse. I removed two wing nuts but cannot remove assmbly. Is there another wing nut holding it in. I cannot find it?
3 wing nuts. here is the info needed.
gmlogoflat.gif Service Information
bhome.gifbpublication.gifbnumsrchbutton.gifbnews.gifymkbutton.giffeedback.gifbhelp.gif
2005 Buick LaCrosse ' Allure, LaCrosse VIN W Service Manual ' Body ' Lighting Systems ' Repair Instructions ' Document ID: 1537542 Tail Lamp, Turn Signal Lamp, High Mount Stop Lamp, License Lamp, Backup Lamp Replacement - Rear
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Turn Signal/Stop Lamp Assembly Replacement - Rear 1
Nut, Turn Signal/Tail Lamp (Qty: 3)
Tip
Pull back rear compartment carpet to gain access to lamp.
Tighten
2 N·m (18 lb in)
Lamp, Turn Signal/Tail Lamp
Tip
Twist the bulb socket and pull inward to replace the bulb.
License Lamp Replacement 3
Screws, License Lamp (Qty: 2)
Tighten
2 N·m (18 lb in)
Lamp, License Lamp
Tip
Jul 29, 2011 | Buick LaCrosse Cars & Trucks
Tip
How do I change my headlight?
On 97 and up Oldsmobile Silhouette, Pontiac Montana, Pontiac Transport, and Chevy Venture Van,
  • When you open the hood and look at the headlight assembly. At the top between the turn signal and headlight there is a black plastic wing nut. Unscrew that wing nut to remove the side marker light. After removing that nut persuade the side marker light to slide forward. That's the only thing that locks it in place. Untwist the socket to replace the turn signal bulb. Since that is out now...There are two more wing nuts just like the first one that hold the headlight assembly in place on top of the radiator support. (The black plastic piece the headlight is mounted to) Remove these two wing nuts and lift up on the whole assembly. Those are the only things that actually lock it into place. Once you slide it up off the studs the wing nuts were on. Unplug the plug from the back of the light (use a flat screwdriver to lift the tab a little). Twist the round plastic ring that holds the bulb in. The bulb should pull out now. Don't touch the new bulb with your fingers as it is a halogen bulb and the oil on your fingers will cause a hot spot on it, causing it to fail SOON. If you happen to touch the glass part of the headlight bulb, clean it with rubbing alcohol. Reverse the steps...go eat dinner.
If this pertained to your vehicle and helped in any way please take the time to rate, as I took the time to write it. Thank you.
on Feb 28, 2010 | Chevrolet Venture Cars & Trucks
How do I change front blinker bulb on 2003 chev impala
First,
  1. Turn the engine off and open the hood. Pry up the two fasteners from the radiator air baffle with a flat head screwdriver. Move the baffle to the side to access the top of the headlight case.
  2. Step 2 Pull up the two metal rods behind the headlight case. These secure the case to the car. You may need your pliers to pull them up.
  3. Step 3 Gently pull the headlight case out to access its rear. On the rear, you will find several black dust covers. Twist off the dust cover closest to the fender (the outward dust cover) to access the turn signal bulb.
  4. Step 4 Turn the bulb module counterclockwise to release it. Unplug the electrical connector from the bulb module. Connect the new bulb to the electrical connector (don't touch the glass with your hands; hold it by the plastic piece). Insert the bulb module in the turn signal housing, turn it clockwise and screw the dust cover back on.
  5. Step 5 Insert the headlight case in the mount. Push the pins back down to secure it. Position the radiator baffle in its place and insert the fasteners.
  6. Rear Turn Signal Bulbs
  7. Step 1 Open the trunk. Remove the net from the side mounted wing nut (on the side with the faulty turn signal). Twist the wing nuts (there are two per side) counterclockwise to remove them.
  8. Step 2 Peel the carpet layer back to access the rear signal lamp wing nuts. Twist these wing nuts (two per side) counterclockwise to remove them and release the rear signal.
  9. Step 3 Carefully pull the rear signal assembly away from the Impala. The rear turn signal is the inner bulb (closest to the trunk). Press the tab on the bulb module and turn it counterclockwise to release it from the rear signal assembly.
  10. Step 4 Pull the old bulb straight off the module (don't twist). Insert the new bulb in the module. Depress the tab on the connection and insert the module back in the assembly. Twist it clockwise.
  11. Step 5 Insert the rear signal assembly. Re-attach the assembly's wing nuts and push the carpet layer back in place. Tighten the other two wing nuts to secure the carpet layer and reconnect the cargo net
May 09, 2010 | 2003 Chevrolet Impala
I am trying to change a headlight. I can't can not
The headlight assembly (1993 Grand Caravan) is held in place with three plastic "wing nuts" that rotate on the ball-end (front end) of the adjusting screws. One "adjusting screw" (the one on the bottom, inboard side) is not for adjusting, just for mounting. The other two adjusting screws take a torx T15 in the front end of the screw.
Removing the headlight assembly is somewhat of a trick - it seems like it takes a special tool to reach the "wing nut" and turm it 1/4 turn (90 degrees) CLOCKWISE (so the "wings" are vertical). When all three of these mounting "wing nuts" have the wings vertical, the headlight assembly just pulls forward and off these mounting nuts. Place the new assembly back over the "nuts", turn the 3 "wing nuts" another quarter turn, and the new unit is mounted. Probably not even a need to re-adjust the headlights, but you should check.
The PROBLEM, is that it appears to take a special tool to reach and turn these wing nuts without breaking them (yes, the old ones get brittle). I tried a socket (did not work), and then long needle-nose pliers (broke one wing nut), then a 1/2" open-end wrench (which at least worked). However, pushing the new assembly back over the wing nuts, I broke another wing nut. So, I broke 2 of the 6, and one was broken when I started.
Now I need to find replacements for these "wing nuts" ... any ideas where to get them?
Of course I can use some washers, some nuts to fit the fine-threaded adjustment screw, and some sort of bushing (maybe cut a short piece of rubber tubing to fit over the adjustment screw). Place double nuts (second nut to lock the first in place) and a washer, then the bushing onto the adjusting screw, then the headlamp assembly onto the bushing, then add another washer, and two more nuts (not too tight) to lock it onto the adjusting screw (which must still be free to rotate). Repeat for each of the 6 mounting points. I have not tried this yet, but ... it should work.
Fabricate a tool to turn the "wing nuts" using a piece of 3/8 inch ID tubing which you file or cut 1/8 inch by 1/8 inch notches on each side of a diameter line.
Apr 22, 2010 | 1993 Dodge Caravan
What is the trick to replacing the high mount brake light globe in my 06 Sonata
Most late model cars are all the same. Open trunk pull carpet away from back of light , remove wing nuts pull lens out. Usually 3 wing nuts.Hope it works.
Mar 09, 2010 | Hyundai Motor 2004 Sonata
How do you change a headlight on a 2001 oldsmobile silhouette??
I don't know if you mean the headlight bulb, or the headlight.
When you open the hood and look at the headlight assembly. At the top between the turn signal there is a black plastic wing nut. Unscrew that wing nut to remove the side marker light. After removing that nut persuade it to slide forward. That's the only thing that locks it in. Untwist the socket to replace the turn signal bulb. Since that is out now...There are two more Wing nuts just like the first one that hold the headlight assembly in place. (The black plastic piece the headlight is mounted to) Remove these two wing nuts and lift up on the whole assembly. Those are the only things that lock it into place. Once you slide it off the studs the wing nuts were on. Unplug the plug from the back of the light (use a flat screwdriver to lift the tab a little). Twist the round plastic ring that holds the bulb in. The bulb should pull out now. Don't touch the new bulb with your fingers as it is a halogen bulb and the oil on your fingers will cause a hot spot on it, causing it to fail SOON. If you happen to touch the glass part of the headlight bulb, clean it with rubbing alcohol. Reverse the steps...go eat dinner.
Feb 27, 2010 | Oldsmobile Silhouette Cars & Trucks
How do you change headlight bulbs on a 2000 silhouette
There are two "wing nuts" securing the entire plastic headlight assembly. One is mounted at the top-inboard(towards engine), And the other is outboard of the assembly. There is also one more plastic wing nut that hold the side marker light assembly Once these three wingnuts are removed, carefully remove the whole assembly. The headlight bulb is contained in the socket... one quarter turn counter-clockwise will remove the socket from the housing.
Good luck and thank you for using Fixya. keep ms posted if you have any other questions.
Feb 25, 2010 | 2000 Oldsmobile Silhouette
How do i change the bulbs? I cant see or reach anything in there.
There are two "wing nuts" securing the entire plastic headlight assembly. One is mounted at the top near the center of the car by the engine. The other is near the fender of the assembly. Once these two wing nuts are removed, carefully remove the whole assembly. The headlight bulb is contained in the socket. One quarter turn counter-clockwise will remove the socket from the housing.
Oct 27, 2009 | 2003 Pontiac Montana
My wing window on my 1987 f 150 needs changed how do i do it
You need to remove the door panel and remove the window glass. Then you will need to unbolt the track that the wing window mounts into. Wing windows usually have screws under the weatherstrip that hold the top in.
Sep 22, 2009 | 1987 Ford F 150
Can't figure out how to straighten and level the camera
if you have lost a srew or wing nut, it will be loose where there should be one. set it up and then try to raise or move it around in one spot. iof it moves than look for a screw hole. the handle itself sets the rotation try unloosing the handle..
Dec 31, 2007 | Quantaray QSX-DigiPro 8500 Tripod
Electrical Supplies Logo
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
