Question about Acer Aspire 7720-6569 Notebook
Backlight on Acer Aspire 7720-6395 gone instantly
I was surfing the web and the screen went blank (mostly) you can still see the screen if you take a bright light (flashlight) to the screen and see the highlighted area. everything appears fine except the backlight is gone. I have tried using the FN+keys to adjust brightness with no change and rebooted and although it is uniform the screen is blank except where you take the flashlight; then you can see that area. I tried system restore too (fun by flashlight) I do have external CRT and I have not tried it yet-not sure exactly what I would prove except that the backlight is not on my CRT or perhaps my video card is bad or that the backlight control is on the videocard and I need a new one.
  • 1 more comment
  • netjet02 Aug 29, 2009
    I solved it-it was the LCD inverter; I just replaced it and the screen was fine fortunately it wasn't the screen or backlights.
    I solved it it was the LCD inverter. I replaced it and voilà it was fixed. All you have to do is make sure you get the correct inverter for your model.
    I have no idea how my post got there 2x and different also. Well at least it is the same information.
The backlight is typically part of the screen assembly. You will need to order a new screen from Acer, and/or have a professional install it. Unfortunately, this is not a repairable item without proper training (component-level soldering is required, among other things); you will need to replace the entire screen.
Posted on Aug 28, 2009
    Sniper:
  • 86 Answers
Bud there is a chip in the back of the monitor which enables the back light it a fix only a pro ca do its cheap enough but monitors now are fairly cheap so i look into repair but if not then sry a new one is needed
Posted on Jul 26, 2009
Acer aspire one no boot menu screen blank power light on no other lights showing except a brief flutter on when using power button when pulling power lead out display show flicker of light
sounds like your lcd inverter may have went out,,,thats a good chance ,,its what powers ur lcd backlight,,check acer website for support,,
Nov 03, 2010 | Acer Aspire One PC Notebook
Backlight on display went dim
If the backlight has failed or a cable is loose you can replace or repair the backlight of the monitor.
replacement parts are available at
www.pchub.com
www.acerparts.com
I suppose the keycombination FN and arrow up or down has no effect?
Aug 03, 2008 | Acer Aspire 5315 Notebook
Ny acer aspire one only shows blank screen
The backlight have went out on your screen. I had this happen on an old laptop2_bing.gif I was messing with. Check the link below for some tips.
DARK SCREEN If you shine a light on the screen, can you somewhat see the screen? Does the laptop power up properly? (can you hear it running?) Hook up an external monitor to your laptop, does the external display properly?
Mar 01, 2010 | Acer Aspire One PC Notebook
Aspire 1360 black display
the most common fault is the inverter which sits just behind the screen bezel if you are confident in taking things apart it is something you can do yourself check out this web site for help might not be the same laptop but principle is the same hope this helps
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Nov 26, 2009 | Acer Aspire 1360 Notebook
My acer 4520's screen is blank when i'm turning it on.
There are approx 4 reasons why this might happen:
  1. The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  2. The panel has died - Need a new panel
  3. A cable has worked itself loose or is broken
  4. The inverter has gone - Need new inverter
  5. Long shot, the bios has got corrupted - Engineer could re-flash the bios
  6. Long shot, Mainboard onboard graphics has gone - Need new mainboard
My personal opinion is that the backlight or inverter has gone - Either way it needs to be opened up to repair it, consult a service centre and get a quote or repair it yourself if your up for it.
Thanks
Sep 05, 2009 | Acer Aspire 4520-5582 Notebook
Black blank screen of my Acer aspire one notebook
FN + F6 Turns the display screen
backlight off to save power.
Press any key to return
Try
Dec 30, 2008 | Acer Aspire 5100 Notebook
White blank screen
<Fn> + <F6> Screen blank
Turns the display screen backlight off to
save power. Press any key to return.
Dec 30, 2008 | Acer Aspire 4315 Notebook
Screen went from Red to Black
It Needs a new Backlight period.(Red hue is clue before complete failure). 15.4" Widescreen? Weve replaced hundreds and some can be a pain.. Run on external monitor until you can get it in for repair.
There are a ton of businesses that can replace these besides us where are you located?
Feb 29, 2008 | Acer Aspire 5100 Notebook
Display
A really dim display like you're describing is most likely a backlight problem.  If your inverter went bad you wouldn't have any display at all.  you need to get your backlight changed.
Oct 10, 2007 | Acer Aspire 5002WLMi Notebook
Acer Aspire 7720-6569 Notebook Logo
506 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
