First the dryer ran for abotu 30 seconds and stopped with an error code of "he". Repairman replaced heating element only, did not other troubleshooting. He leaves and the dryer still does not dry. Repairman comes back out, replaces the main circuit board, gets heat (I even verified)then leaves. I put a load of wet clothes in and no heat right away. I unplu the unit, checked the 4 wire cord, and hook it up right (the green and white wire together)take the top cover off, put it back on. Plug the unit back in and got heat. Put wet clothes in again and no heat. I have tried different settings, differnet het levels, different time and still no heat. This has been going on since July 1st and to say the least my wife is fed up. Does anyone have a solution?
  • 3 more comments
  • schrodtbob Jul 26, 2009
    The dryer is a Samsung, model DV337AEL
    Where would I find this coil?
    first the dryer ran for about 30 seconds and stopped with an error code of "he". Repairman replaced heating element only, did not other troubleshooting. He leaves and the dryer still does not dry. Repairman comes back out, replaces the main circuit board, gets heat (I even verified)then leaves. I put a load of wet clothes in and no heat right away. I unplu the unit, checked the 4 wire cord, and hook it up right (the green and white wire together)take the top cover off, put it back on. Plug the unit back in and got heat. Put wet clothes in again and no heat. I have tried different settings, differnet het levels, different time and still no heat. This has been going on since July 1st and to say the least my wife is fed up. This is a Samsung electric dryer, model DV337AEL Does anyone have a solution?
    I have tried in timed and automatic modes.
    I will have this checked out
  • 339 Answers
Try running it in a timed mode rather than an automatic one. If this works then you probably have an issue with the moisture sensor circuitry. Perhaps the repairman re-installed it incorrectly.
Did he test the heating element that was replaced? I'm betting it was good all along. If it's warranty it's an annoyance, if you paid then I'd want to check.
Posted on Jul 26, 2009
  • ted1430
    ted1430 Jul 26, 2009
    Try it with some dry clothes, I'm curious if it will heat then. Shouldn't really have much effect though as the "moisture" sensor is actually a temp sensor. The washed clothes aren't unusually hot are they?
    It's beginning to sound like the replacement control board was bad. Wouldn't be the first time a replacement part was defective but this is strange behavior all the same.
  • 3,037 Answers
Can you give me the make and model number of the dryer in question. I will assume for now that it is an electric dryer and so the following should apply and be checked.
Some models use a thermal safety limiter or thermal fuse which could open the circuit to the heat element. These are used to prevent a runaway or over heat condition and are often found mounted to the blower or heater element housing. These devices are a fairly current development and may not be found on very old dryers.
The element coil could be burnt out. Dryer elements are bare wires coiled like springs, when they fail the wire will break opening the circuit. This breakage could be intermittent, only opening as the element expands as it heats. Sometimes the element coil has to be physically checked for breakages, especially where the coil goes through ceramic insulator which could hide a breakage from plain view.
Let me know what you find.
Benjamin
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Frigidaire AEQ8700FGO dryer will run (and heat) for about 30 to 60 seconds then stop. 3 lights above start button will flash rapidly. Depressing cancel and start buttons at same time will not work for...
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it
Sep 30, 2013 | Electrolux AEQ8700F Electric Dryer
Dryer wont stop buzzing
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
Electrolux
Hello Curtis - Typically, error code E61 indicates a Heater Relay failure. At first the heater was grounded, and now possibly the heater relay. When the heater grounded it could have shorted the relay as well. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
May 01, 2013 | Frigidaire Electric Dryer
I was drying and the dryer shut off and gave an error message of E64
Hi
Error code E64 means Heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and “cancel” buttons simultaneously for 3 seconds. If the error appears again then you’ll need to check heater coils and connections for open circuits. Use a multimeter to check the heater element, use Rx100 setting on the multimeter. It should display 30-33 K ohms as the resistance. If it is less than this or exceeds this limit then the element has gone bad and you would need to replace the element. Hope this helps...
Daniel
Sep 13, 2010 | Electrolux EIED55H Dryer
Error message e64
Hi
Sep 07, 2010 | Electrolux EIED55H Dryer
My Neptune dryer has stopped heating. Is there
Dryers are very simple. You probably just need a new heater element. Usually just remove the back panel, remove the element, take it to a appliance parts store, get a new one and install it. They don't cost very much maybe $20 or so...
Jul 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My dryer stopped heating up so I tried to fix the heating element. I noticed in the other one that some of the coiles broke in half so I knew this was the problem. Well I bought a new one, hooked it up and...
Could be a defective element, but it also could be your thermostats faulty...give them a check.
Normally you can only hook up the heating coils one way...I do not believe that would be the problem.
Hope this helps
Sep 29, 2009 | Whirlpool LEN2000PW Dryer
Started dryer at 6 am, got home at 5pm it was still running
if it was set on timed dry replace timer if it was on auto dry check element thumbs up
Aug 12, 2009 | Kenmore 62882 Electric Dryer
Maytag MDE6700AYW Electric Dryer Error Code "he"
Could be the thermistor, or the element, or the control board. You have to use a multimeter to troubleshoot the problem. You unplug the dryer, disconnect the element and use an ohmmeter to test the element for continuity.
If you don't have a multimeter, you could replace parts randomly to see if you can find the problem
Jun 29, 2009 | Maytag PYE2300AY Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
