Question about Audio Technica AT-PL120 Turntable
Very low audio output
My turntable puts out sound but I have to turn the volume almost all the way up to even hear anything. I noticed another answer to this problem stating that the cartridge may be not connected properly but I have very carefully made sure the cartridge is in the right spot and still very little sound. I am running the turntable through a receiver and my surround sound speakers.
  • 515 Answers
Re: very low audio output
Make sure your receiver has a PHONO input. If you are connecting it to a LINE or AUX input, then there is not enough signal to boost the sound coming from the turntable. Turntables require a PHONO input, because phono input's have a pre-amp on them, which boost the turntable signal. If you do not have a PHONO input on your receiver, you will need to buy a Phono Pre-Amp.
If you have a phono input, then you might have an issue with the turntable's RCA cables, or your cartridge may be at fault.
Posted on Nov 22, 2007
0 characters
3 Points
Volume is too low even with Gain turned to maximum. Also talking during recording gets picked up on the recording.
Your computer sound controls govern input volume and the use of a microphone. If you have a mic, find the control and turn it OFF.
Mar 04, 2011 | ION Audio TTUSB 10 Vinyl Recording USB...
My crosley CR2406A unit has very low audio output even at max volume.
Jan 16, 2011 | Crosley CR248 Turntable
No sound after multiple attempts. No sound levels changing
several people are having this trouble but most seem to work ok .. the unit has its own built in preamp and digital interface so, in this case, you dont have to worry about what cartridge it has .. in fact you can hook its rca outputs to the aux of an amplifier (not the phono input) .. or you can connect them to your amplified computer speakers thru an RCA sterio to 1/8 inch jack adapter ... i am working on a solution remotely since i dont have the unit yet ... but here is a suggestion (for xp) .. find the volume icon in the bottom right task bar .. double click on that .. that should bring up a box with several volume controls .. make sure none have "mute" checkmarked .. turn up all the controls so you cant miss anything if it comes thru ..try the table ... now click on "options" in that volume control box then "properties" then put a dot for "recording" .. select all of the volume controls in the bottom box .. now click ok .. that will give you some level controls for recording . turn them up ..then select them one at a time to see if any work (with table playing) .. if none of that works then there is likely an incompatability .. you might look for upgraded drivers for your audio card .. .. i will likely have more on this as i remotely get one working or if i can find one to play with .. maybe a few days .. some audio cards turn off sound outputs when you are in the record mode .. thats so you dont get screeching thru the mic input .. but there is usually a way to defeat that .. the units software should have done that for you .. i have found some popular laptops that horrably dont have sterio inputs (only monoral for the mic input) ... on a few that can be fixed with special software but on others (like my inspiron 6000) there is no hope ... i purchased an audio input adapter that connects to the USB port .. that gives you several analog inputs that are sterio .. your turn table's digital output doesnt need analog inputs so you are ok unless you want to use the RCA jacks as audio input ..
Jun 02, 2010 | ION Audio iTTUSB Turntable
Doesn't output sound
If the unit is used, pull out the cartridge and clean the pins really well.
Make sure the very small connectors that fasten to the cartridge are not loose when you put them on. If so just squeeze them gently and make sure they are clean also.
Jan 10, 2010 | ION Audio iTTUSB Turntable
ION turntable volume is low when plugged into a receiver.
Either the cartridge has failed, or an internal amp in the record deck has, or despite what you say the receiver has. I will clarify this for you. Magnetic cartridges need a pre-amp before it gets amplified by the pre-amp and power amp of your reciever. If that pre-amp fails you will still hear the low sound from the deck, but all others cd/tape would be normal as they don't go into the deck pre-amp.
All you need to is trace the circuit. Find the magnetic cartridge pre-amp and find where it joins with the pre-amp of the amp! If you stick a screwdriver at that point, you will get a buzz at normal volume on each channel. The cartridge pre-amp has gone if you do get a buzz!
You probably find it's a single IC that's gone, some are prone to static problems.
Jan 01, 2010 | ION Audio iTTUSB Turntable
I can't hear music through computer speakers. Speakers are functional. I can hear low volume music from turntable. What's up?
Have you selected a different setting in the audio control section of your computer? For example: wave out, instead of line in or vice versa. Is the audio control input set low?
Aug 04, 2009 | ION Audio iTTUSB Turntable
Very low sound comming out pioneer pl300
Hi Jack.
Just confirm that it is plugged into a PHONO input (designed for turntables) Cannot use AUX/TAPE etc type inputs. If not, you will need an RIAA preamp from local electronics/Audio store. If that is OK, then try replace stylus first and the cartridge (may be just easier to do both same time). No volume control in turntables and it can only be 3 things (generally) Input, stylus, cartridge
Best of luck
Jul 24, 2009 | Turntables
Volume is low on my turntable
You have to amplify the output from your turntable output to the input of your amplifier. To do this you can buy what is known as a pre-amp. Radio shack probably still sells them.
Be sure to ground your turntable to your amplifier and not the pre-amp. This should stop any hum or at least diminish it. Bear in mind that your records will not sound as loud as your CD's. Hope this helps.
Feb 10, 2009 | Numark TT1520 Turntable
Installation of a Technics Turntable
isnt the black wire the ground/earth wire??
Nov 29, 2007 | Technics SL-BD22 Turntable
Audio Technica AT-PL120 Turntable Logo
482 people viewed this question
Top Audio Technica Turntables Experts
Electro Med Services...
Colin Stickland
Colin Stickland
Are you an Audio Technica Turntable Expert? Answer questions, earn points and help others
