Question about LG Flatron F700B 17" CRT Monitor
LG f700b raster problem
Hello
my monitor is LG f700b.when i turn it on there are some raster lines at the top of screen that reversed to down (about 2 cm) .top of screen is blank because that lines are my monitor top screen.
about 2 hour after turning monitor on this problem decreases.
thanks for every one help
  • LG Master
  • 5,568 Answers
If the lines are slanted, you are seeing 'retrace' of the horizontal sweep. The distortion at the top is probably caused by a failing electrolytic capacitor in the vertical deflection circuit or in the power supply filtering for that circuit.
If you want to try to find this problem on your own, use great caution! There are exposed parts that can carry very nasty if not fatal voltages.
Go to any electronics parts source and buy two cans of 'freeze spray.' Expect to pay $4-5 dollars each for them. Using this on a 'live' monitor makes it still a little more hazardous since the cooled parts will form frost that may be conductive and I recommend keeping one hand behind your back so even if you touch something 'hot' you won't have currents passing through your heart.
With the rear case removed, you might drape a clean towel over the guts to let it warm up as it would if cased. When you notice the distortion going away, remove the towel and start spraying short bursts at the cylindrical parts, mostly those of 'medium' size ranging from ~ 3/4 to 1 1/2 inches in height and 1/2 to 3/4" in diameter. These are the parts with values most likely to be failing.
If you can identify the power transformer, a largish block, mostly black, check those capacitors first. You will need a mirror to watch the screen for the worsening of the distortion again and be patient; the parts you are cooling have some thermal mass so the effect is not immediate.
If you find one that seems to affect the picture, then, if you have one, direct a hair dryer (blower type) at that area to see if you can recreate the problem several times.
If you can isolate one specific part, note the value of it; it will have several printed items: - Capacitance - this will be such as this: '100 uF' - Voltage - '63V' - Polarity - this will be marked with a '+' and maybe a minus on the other leg. This is important! Any new part must be installed with the correct polarity if any is shown and it will be present on this type of part.
These parts are very inexpensive so if you cannot decide which one is at fault, replace all of them in that area; they cost from 20 cents to a buck. If you have no local electronic parts store (Radio Shack doesn't have much any more) you can order them from Mouser Electronics. Mouser has NO minimum charge and adds only real postage/shipping charges. You'll find them at mouser.com
If you decide to go this route, you will have to acquire and learn to solder with a soldering iron. Or if you have a friend who is an amateur radio operator, they will probably do this for you.
Removing the board from the bottom of the case is pretty easy, just make sure the monitor has been OFF for a while otherwise removing the thick cable from the CRT will be a really memorable experience!
Looking at the bottom of the board, note the look of the other solder joints there and do your best to duplicate them when installing the new part(s), bad solder joints can make your repair futile.
Or, you can stuff the wole thing in an envelope and send it to me ;-)
If you have been happy with this unit, it is worth the repair, since LCD monitors are often dead soon after the warranty has passed on.
Good luck
Posted on Jul 26, 2009
Lg e700sh monitor out of shape i need the settings of original shape
try factory settings
- Press Power to turn screen off
- Press and hold Select/Auto
- Press Power to turn screen on. LED will be Orange instead of Green
- Release Select/Auto
- Press Menu
- You will see 2 additional options (Factory 1 & Factory 2)
- Exit as normal
- To return LED to Green, Power off then Power on
To reset colour:
- Choose Factory 2
- Choose Auto Color1
Jun 14, 2011 | LG Flatron F700B 17" CRT Monitor
Control locked how can i unlock it?
To unlock the On Screen Display (OSD) lock, hold down the menu button for 20 seconds until OSD unlocked shows on the screen.
Please rate my answer if this helps,
Chris
Mar 03, 2011 | LG Flatron F700B 17" CRT Monitor
My monitor is LG FLATRON E700SH out of shape it is not getting adjusted can u please give me the perfect shape specifications
I have a problem of setting screen onto moniter ... So just suggest me what is Screen Position , Shape Size to me
Oct 08, 2010 | LG Flatron F700B 17" CRT Monitor
I got a black and white signal (picture ) also it is very weak , i have to increase the brightness to be able to see the black and white screen , when i turn it on some times after 5 or 10 or30 minutes it...
it usual problem with LG monitors. u can fix it just by soldering vedio board epecially vedio ic affixed on crt. bt do it gently becoz any bridging of solder may damage ur microcontroller.
Sep 07, 2010 | LG Flatron F700B 17" CRT Monitor
My monitor display size probs
u can adjust the screen appearance by presssing the buttons on the front...do a hit and try as i am not sure which buttons do what function in ur monitor and how they are positioned...normaly it will have function/up/down/set etc..eash option will increase, decrease, move up, move down, left, right, zoom out etc
Dec 24, 2009 | LG Flatron F700B 17" CRT Monitor
KDSusa Analog monitor
I would check the video card , then the connector and if the lines are still there , then you need to replace the monitor
Jul 26, 2009 | LG Flatron F700B 17" CRT Monitor
Audio ok, no video
I’ve never seen this kind of video output caused by a bad video cable or bad FL inverter board. it was fixed after I replaced the monitor
Apr 03, 2009 | LG Flatron F700B 17" CRT Monitor
LG F700B Lines at top of screen
HEY BUDY
i have same problem (exactly same!!)
see here i hope it is usefull
http://www.fixya.com/support/t2664392-lg_f700b_raster_problem
if it solve your proble please notify me
Feb 09, 2009 | LG Flatron F700B 17" CRT Monitor
Yellow Screen
Furst, check the video signal cable, if you can, try a replacement. Try removing and then refitting the original, sometimes this clesans the connections
Dec 26, 2008 | LG Flatron F700B 17" CRT Monitor
Monitor screen appears yellowish
resolder components on the CRT neck circuit! the color ICs or Transistor connections migth have loosen up!
Dec 06, 2007 | LG Flatron F700B 17" CRT Monitor
LG Flatron F700B 17" CRT Monitor Logo
348 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
