Question about Samsung TL34HD / NV100HD Digital Camera
I press the power button and two seconds later there are two beeps and the camera shuts off. The battery is fully charged...
  • Samsung Master
  • 19,396 Answers
Two beeps mean only that there is a problem.
Whenever a fault is detected Samsung cameras prompt with two beeps, there is no error code, and the camera usually must be tested by a technician to find the fault.
All you can do is trying to remove SD card, and replace battery with fresh alkaline ones. Then try to turn on the camera, when you turn it on , if it still does not start, try tapping gently the back of the camera to help lens out, just in case the fault is lens error.
Also try leaving the camera to rest for three or four days in a dry place with no battery. This can help if camera is faulty because of liquid damage.
If that does not work, then the camera must be disassembled and tested, in that case you can get a quote here:Advance Camera.
Regards.
Posted on Jul 26, 2009
Camera shuts off when shutter button is pressed.
I'd try replacing the battery first. It is common for a low power battery to not allow the camera's computer to read what it is supposed to do correctly. If the new fully charged battery doesn't fix it, I'd then contact customer service.
Apr 29, 2015 | Canon PowerShot S2 IS Digital Camera
The camera comes on when the powere button is
Usually this is a sign that the battery is weak or not charged enough.
Make sure you have either a new battery or the battery is fully charged, then test the camera again.
This camera takes a Sony NP-BK1 Li-ion rechargeable battery (or compatible).
If the battery is good and is fully charged, then there is a problem in the camera, and needs repair or sell it as parts or as is (if repair cost is too much) on a site such as Ebay.
Apr 15, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
Battery charged, however camera will not stay on
This is a firmware problem that is very common in newer electronical devices especially cameras. You may get lucky enough to find an upgrade program online, but most chances are that you will have to send the camera in to the manufacture and they will repair it for $50
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Camera won't turn on - makes strange sound
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at mike@digitalcamrepair.com
Feb 26, 2009 | Casio Exilim EX-S600 Digital Camera
It won't power on
Batteries are too low. Install new alkaline batteries or better yet metal hydride batteries that have been fully charged first.
Jul 23, 2007 | Samsung Digimax S630 Digital Camera
I832
shut off the camera manualy
Jun 20, 2007 | Polaroid i832 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries. Please refer to the section pertaining to Battery Life.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Samsung TL34HD / NV100HD Digital Camera Logo
123 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
