SOURCE: Dish Network Box, Technics Receiver, RCA LCD TV connections
I would use the s-video out & red & white rca audio out on dish box to s- video & audio in on the t.v., then audio out from t.v.(RCA, red & white) to one of the inputs (RCA) on the receiver.
SOURCE: TV CODES FOR 32'' RCA HD TV
if you bought a new rca tv, the codes have changed. until the cable companies catch up, you will need to use the remote that came with our tv AND the remote that came with your comcast box. Or, you can buy a LEARNING UNIVERSAL remote. this is different than a regular universal remote.
SOURCE: TV screen reading no signal. We have satellite
tune in tv or put tv in AV / EXT mode the no signal means not tuned or on areal in tv
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
SOURCE: Remote Problem
Remote codes are programmed into the remote at time of and since the TV was manufactured after the remote it will be unable to have the code as TV manufacturers change codes often. You can try having a 20 or 21 remote sent to you but ensure it will work with your receiver. These remotes are programmable and ar able to learn functions of other remotes. Thanks for using Fix Ya.
