Question about Whirlpool ET4WSKXS Top Freezer Refrigerator
Refridgerator drips water from the cold air vent.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
If your freezer is on top,you most likely have an overflowing defrost drain. there is a drain that starts in the freezer and continues down to the drip pan. start at the top and work your way down.
Posted on Jul 26, 2009
2 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: water drips inside our refridgerator
Sound to me your refrigerator has a defrost condensate drain blockage.I There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com SEA BREEZE TIP'S
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
have some information what to look for and what you need to do.
Posted on Sep 13, 2009
Lg-LRFD25850 water dripping from bottom lt refridgerator door , refridge has water on that side
Probable drain hose issue.Hose is plugged up and it cannot get to the evaporator.Remove lower vent assy and see where the water is coming from.
Feb 15, 2014 | Samsung RF265AA Bottom Freezer French Door...
Water in refridgerator
Have a look inside fridge compartment (especially the "roof", if it's a top-mount freezer) & see if you can see any ice build-up (look inside vents that allow cold air into fridge from freezer section. Also, if top-mount freezer, look inside the freezer compartment for ice build-up on "floor", inside vents, or on back wall. These symptoms, combined with water dripping from lots of the "roof" of fridge section (in a top-mount freezer model), can mean several different problems, so best to re-post with more info/symptoms included.
If there's no ice build-up (& the dividing area between fridge & freezer sections isn't particularly cold, which otherwise might indicate hidden ice build-up), it can be as simple as a plugged or obstructed drain tube, which is VERY COMMON. Easiest solution for this latter problem is to use a flexible plastic tube (think similar type as attached to aquarium air pumps), stuff it into drain hole, and blow on the other end. Sometimes you have to blow quite hard to clear an obstruction or complete blockage. If you can't clear the drain tube, it's likely a different problem. Again, a re-post with more info/symptoms will help narrow it down.
Sep 17, 2013 | Roper Refrigerators
Water collecting on top shelf of refridgerator
Your defrost drain line in the freezer has stopped up. The defrost water is coming in through the air vent to the fresh food section.
Turn the unit off and use a hair dryer to defrost the drain hole located behind the freezer panel.
Jun 21, 2011 | Kenmore Top Freezer Refrigerator
Have water dripping into refridgerator from cold air vents
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 07, 2011 | Microwave Ovens
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
One of our A/C vents is constantly dripping. We have not used the A/C in over 3 months and this is just started to happen. Why? We live in MA.
The reason for the vent dripping is because you have warm high moisture content air going up into the cold vent.
This creates condensattion that fills the duct and then drips out the vent.
There could be quite a bit of water up there in the duct if there is a pocket for it ti lay in...
You need to get the vent closed off tight so that warm air cannot back into the vent while you are not using the A/C over the winter.
This probably has not happened but just in case... check that there are no holes in the ductwork that could be allowing cold air to enter the duct work and fall into the house. This will also create condensation at the vent.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 07, 2009 | Heating & Cooling
The refridgerator is on top and warm, we think the airflow is plugged because the freezer is very cold. How do we get circu- lation? We have emptied the freezer and most of the fridge and have cleaned the...
The access cover for this type of refrigerator is in the refrigerator section, you must remove the screws and the cover will slide out, if the fan motor is not turning or you have ice build up , you need to replace the fan motor, because it is not working properly, a new motor will allow the air to circulate and this should correct the cooling problem.
Nov 12, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refridgerator side not cooling. No air movement.
vent clear but vent opening arround vent frozen or coil is frozen eithor way you probably need a thermostat and a timer
Jul 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
Fridge
Clean the door seal and ensure that there are no gaps between the sealing surfaces of the door seal and the refrigerator, if there is, relatively warm moist air will continually feed condensible moisture to the cold gap in the seal and the condensed water will drip on the floor. If the door seal its self is broken or torn it will have to be replaced to stop the drip.
Hope this helps.
Mar 16, 2008 | Refrigerators
Whirlpool ET4WSKXS Top Freezer Refrigerator Logo
110 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
