Question about Dell 810 All-In-One InkJet Printer
Paper not properly feeding thru to print and the paper crimps
We cant get the printer to feed the paper properly! working great and then bam, the paper wont feed through and it crimps up at the point of the feeder...
    Problem Solver:
  • 15 Answers
Some of your rollers might not be working.
Posted on Jul 26, 2009
Posted on Aug 15, 2009
I have a paper jam that i cant get to. The paper is coming out with a line that is crimped in the middle. I can hear paper rolling but cant see anything to get out. The paper that comes out has a line...
Check for any debris or any stuck object inside the unit, it could be a small piece of paper has left inside when you encounter any paper jam problem before.
Better to use a better high quality paper on your copier, it sometimes the problem like this happen because of low quality paper use, the paper roll inside and the paper cannot feed out properly out of the copier.
Let me know for further assistance.
Thank you for using fixya,
Jun 22, 2010 | Canon imageCLASS D860 All-In-One Laser...
Printer wont feed paper through to print on
there are a lot of steps that u need to follow.. I tried to get the detailed link but it didnt seem to work properly.. so try this link below.. http://tinyurl.com/2kdp28 once on this page.. go to support & service.. and search for FEED PAPER... and select the second answer there.. and follow steps there.. let me know if this was helpful to u.. regards, guru
May 05, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Incapable of feeding paper.
There may be debris blocking travel near the feed roller, or the feed roller is not turning (check for broken drive belt or bad gearing).
Jul 18, 2009 | Dell 810 All-In-One InkJet Printer
My Epson DX4000 Printer keeps getting paper jams and wont print
still printing but the paper goes no further?. It may be the paper is locked by paper feeder mecahnics, Open case, check it, and may be there is something "material" broke.
May 24, 2009 | Epson Stylus Pro 3800 InkJet Printer
Will not feed the paper.
it probably needs a roller assembly replaced
Jan 16, 2009 | HP PSC 1315 All-In-One InkJet Printer
Epson Sx200- Paper wont feed
Just a thought,as I had a similar problem.The instructions are abysmal,but it may be worth having a look where you feed the paper in and squeezing the grey plastic gizmo,and moving it to the left to allow the paper to enter the feed properly.
Dec 26, 2008 | Epson Stylus Multifunction Inkjet Printer/...
I have a lexmark E120, great little printer just went to print and it was down to one sheet of paper, I got a batch of papers to feed in, as I was printing a large doc, and in a split second it started...
In the back of printer you have door. Open it and there you can clear jam. Remove paper but slowly and easy. Close door and it will work fine.
Good luck.
Sep 15, 2008 | Lexmark Office Equipment & Supplies
Cant get paper to feed on samsung clx 2160n
Most such printing problems stem from incorrect paper types or paper loading. Make sure that your paper is loaded properly, and that the paper type is made for your specific printer.
Check the hardware.
If paper is not feeding properly into the printer, the problem may stem from hardware failure. Check the feed assembly to see if all the parts are in working order. You may be able to manually advance the paper in order to see which component may be failing. If necessary, clean the paper pickup rollers to make sure the paper path is free of sticky dirt and debris.
Jun 27, 2008 | Samsung Office Equipment & Supplies
Printer wont feed paper on one side
This may sound strange, but it works more often than not. Try unplugging it, turning it upside down and shaking it vigorously. Also, take some canned air and spray into where it feeds the paper. Just be careful not to spray into the ink-head.
Mar 06, 2008 | HP PSC 1610 All-In-One InkJet Printer
Loading printer paper
Where I was guiding the paper, after feeding the paper through the back of the machine (the slot is located on the outside of the back of the machine), the paper naturally wanted to enter underneath the black plastic plate where it would end up underneath the entire printing mechanism. As the instructions indicate, the paper does not actually feed "under the black plastic plate", it should feed through it. There are two rectangular silver tabs, one on each side of the proper paper entry slot. I cut the paper at a very slight angle and finally found the magic entry point. Also if you make an arrow with the paper by folding the sides, it will help guide it in that tiny silver slot. Because the machine is so tiny, that entry slot is almost invisible, except for those two silver tabs. After you manage to insert the end of the angled cut through the "invisible slot" be sure the entire edge of the paper actually enters the slot so that when you push the "Feed" button, the paper is grabbed and fished through evenly. Hope this helps somebody!
gaframe = true; ' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; document.getElementById("ga_300x250").style.width = "370px"; adsByGoogleRight = "5px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //-->
Mar 19, 2007 | Canon P1-DHV Calculator
Dell 810 All-In-One InkJet Printer Logo
568 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
