Question about EarHugger Around-The-Ear Headphone with In-Line Volume Control Headphones
Can I remove volumn control from my headphones?
Volume control in my headphones are not working correctly. As I increase/decrease volume, sound in one or other or both speaker vanishes. I just bought them a month ago. Is there a way I can remove volume control from these headphones and make it 'direct' and control the volume using only software (media player, etc).
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Aug 10, 2013 | Computers & Internet
Denon receiver problems
Check sound from headphones. These models have been known to have bad headphone jacks that make the unit think there are headphones plugged in even when there isn't. Sometimes just plugging in headphones and unplugging them will fix it for a while.
Apr 26, 2013 | Denon AVR-689 7.1 Channel Home Theater AV...
How to adjust hearing volumn on samsun cell phone
Adjusting the volume during a call Use [up navigation /down navigation ] to adjust the earpiece volume during a call. Press [up navigation ] to increase the volume level and [ down navigation] to decrease the volume level.
Nov 27, 2010 | Samsung SGH-D900 Cellular Phone
Res.sir, i have a hp pavilion dv2000 laptop in this laptop headphone not work
first of all check whether the port is working correctly or not. For that use any other headphones. If they are working then ur present headphone set is gone. Or else if it is also not working then goto control panel -- sound and audio devices and then go to volume --advanced and increase the volume of all the devices present there..and correctly configure Sound Effects Manager which is present in the control panel ..in that u can configure the type of speakers u use or headphones ..there u adjust it to headphone..then the job is done..
Jul 07, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Not able to increse volume.The volume controller on my laptop automatically slides down even if I increase it while using the headphone.
your head phone volume controller /speaker/s has been short circuited so please replace /purchase new headphone
thank you
May 24, 2009 | Logitech ClearChat Pro USB Headset
Volume control on tom tom 830
With the tt on and displaying the map, tap the bottom left side. At the bottom a slider bar will appear. Use your finger to adjust the volumn to your desired level. Another way is to tap the map screen, then tap change preferances, tap the arrow until you come to volumn preferances and change the volume setting there.
Apr 30, 2009 | LG LN735 GPS
Need to adjust incoming calls volumne up
Hi
most phones only allow you to increase/decrease volume of earpiece whilst your in a call. Whilst making a call the buttons on side of phone (up/down) should allow you to adjust volume. Sometimes these buttons also allow adjustment of ringer volume when not in a call. Hope that helps?
Apr 23, 2009 | Cell Phones
Sound coming out of speakers in spurts
speaker volume spinner i.e which is use to increase n decrease the volumn is not working and it has a ball in the end.
if you slowly turn the volume controller nob probably u will get clear sound at one point.
Apr 01, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
HP Pavillion Entertainment PC
hmmm i think you all should buy macs. pcs ****
Feb 27, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
EarHugger Around-The-Ear Headphone with In-Line Volume Control Headphones Logo
301 people viewed this question
Top EarHugger Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an EarHugger Audio Player and Recorder Expert? Answer questions, earn points and help others
