Question about Wesco Manufacturing Wesco 260150 Llhp Hydraulic Lift
Wesco Hydraulic platform lift needs pump valve re-assembled.
Looking for a diagram of how the ball bearings and springs go back in the valve of a Wesco platform lift.
How do I add hydraukic fluid?
There is a rubber plug on the side of the ram which comes out fill to the level of the hole using jack oil .
Apr 03, 2015 | Wesco Manufacturing Wesco Hydraulic...
How to change seals on a wesco pl-54-2230 hydraulic jack
This is a hi-tech job best left to an hydraulic pro for safety reasons.
Jul 12, 2014 | Wesco Steel Hydraulic Pedalift 2 Wheel...
I have just backwashed the pool to remove excess water after rain. When I turned the filter back on the popol is continuing to drain water
If the handle is sloppy you might have a broken spring in the valve. If not the gasket that keeps water isolated to the right path inside the valve head is not sealing. Sometimes it can be debris stuck but often it means the gasket or diverter (key assembly) needs replaced. It is easy enough to inspect. Shut the pump off and put the valve handle between any two positions then remove the six screws around the top. It should lift off for inspection. Remember this area is under a lot of pressure when the pump is on so it wont take much to allow it to leak across. If the gasket is in the valve body it will need to be removed completely and a new one glued in its place. If the gasket is part of the key assembly, it may not be replaceable, so the whole key assembly will have to be changed. If this is the case, I suggest you take it into your local pool store and see if they can help change it out. The key is under heavy tension from a spring. I use a 6" bearing puller to help compress the spring. Please let me know if you need anymore info or if this didn't help.
Apr 14, 2014 | Waterco Pool & Spa
CARBURATOR OF NISSAN 1400 BAKKIE
the ball bearing will be a non return valve for the accelerator pump. When the pump is moved to suck in fuel from the bowl it lifts of the seat and when the pump is pressed down the force of the fuel closes it off and the fuel is squirted in to the manifold.
Jan 19, 2014 | Nissan Cars & Trucks
Need manual to put back ball and spring back into the gun triger housing .
You may have to contact Titan and request an assembly diagram.
Jul 18, 2017 | Air Tools & Compressors
Need service manual for wesco DPL-54 hydralic lift
http://www.wescomfg.com/html/contact_us.htm
Wesco Industrial Products, Inc.
1250 Welsh Rd
North Wales, PA 19454
P. 215-699-7031
F. 1-800-346-5511
Jun 09, 2012 | Wesco Manufacturing Wesco 518X Head Chef...
Need diagram assembly for valve body of 1999 dodge caravn (spring and berring location)
I have several diagrams for the valve body on your 1999 Dodge Caravan including a complete expoded view and diagrams showing valve, spring, and check ball locations. However, I cannot post them here due to size restraints and copyright issues. If you would like to sign up for my premium services, I will be happy to get them to you.
Dec 03, 2011 | 1999 Dodge Caravan
Spring loaded ball bearings - does the ball bearing sit on top of the spring or below the spring??
The ball bearing is a check valve. The ball should be in the input side of the water with the spring underneath.
input side ----->( O/////)-------> output side
Feb 21, 2010 | Jura Capresso Capresso Infinity Conical...
Faucet connection
You only need to put back on the steel clamp that fits over the assembly which holds down the shield, the spring, and keeps the 4 ball bearings in place. The ball bearings may be tricky though as they tend to fall out when your putting the assembly back together.
Dec 27, 2008 | Danby 22 in. DDW396 Free-standing...
The pump "stuck"
I think you do know that you did not properly flush and clean the pump after the last
time you used it......If it is a diaphragm pump, remove the inlet valve and make sure
the valve and spring are perfectly clean....Soak it in paint remover for a day or so
if needed.....Remove the retaining nut which is covering the outlet valve......Clean the
very, very small ball and spring....DO NOT LOSE....Replace all parts when clean....
Also check your hydraulic fluid in the pump's sump.......If it is a piston pump, remove
the inlet valve and make sure the ball is free and not stuck to its seat.....Tilt the pump
on its back and look up into it.....With a pencil see if the other small ball in the piston
is also free....Try to pump warm water through the cleaned pump....Without hose or gun......If it pumps fluid, replace hose and gun without spray tip....Test for flow again.
Then finally replace the spray tip......Chase out the water with the paint.....
The Pump Doctor
Sep 28, 2008 | Wagner 1/2HPPaint Pump Sprayer
Wesco Manufacturing Wesco 260150 Llhp Hydraulic Lift Logo
954 people viewed this question
Top Wesco Manufacturing Plumbing Experts
Tom Chichester
Paul Carew
Are you a Wesco Manufacturing Plumbing Expert? Answer questions, earn points and help others
