Question about Husqvarna Garden
Husqvarna iz4817 wont start, need to back out of garage and geers are locked... told there was a swith to release gears... can't find it... any help?
Look at the rear of tractor There should be a rod sticking out of rear with an indicator showing a cotter pin. you pull rod so cotter pin comes through hole and rotate so that it is held outside of body. Gears should be free
Posted on Jul 26, 2009
My ridding mower when i I put in reverse it works but whenI put in forward geer it wont go
Does the mower have a brake lock? This will often allow you to go in reverse but not forward until released.
Apr 05, 2014 | Garden
My 2009 Lincoln MKZ will not go into gear ....
Take it to garage get the solonoid looked at ,this soloniod releases the gearshift and it could be getting weak or the cables need renewing
Jan 29, 2014 | 2009 Lincoln MKZ
When i put it in gear it starts grinding like it wont go all the way into geer
I assume you have a manual transmission. If so sounds like your clutch maybe shot. To test your clutch put the park brake on while the truck is stopped.. shift into 5th gear and slowly let release the cluth.. the engine should die. If the engine does not die you clutch is slipping and needs to be replaced. How many miles on the vehicle ?
Dec 14, 2010 | 2001 Chevrolet Silverado 1500
The garage door will not open all the way to the top. Is there a reset switch or calibration swith on the opener?
If this just started you need to check the door springs and the drive gear. Both of these will cause this type problem. Check the springs for a broken one and you need to remove the cover from the motor unit and look at the drive gear. It is white nylon and is just in front of the motor.
The make and model number would really help.
Jun 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Husqvarna model 435.Having trouble starting.Do I squeeze trigger when starting? Is there a trigger lock for starting?
Did you read the starting procedure in your OM? It is similar to this:
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
Flooding is most common reason for hard starting in 2-cycle engines.
IPLs and OMs for all Husqvarna saws can be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 14, 2010 | Husqvarna Garden
2003 Jaguar s-type Transmission fault car wont move
First off check the battery. Try and jump start it. If that does not get the vehicle running you may have a problem with your J gate as it will not start unless in park or neutral. If an internal electrical fault has happened then the micro swith may not send a signal to the ecu to allow the car to start. the J gate is the gear selector by the way
Jan 25, 2010 | 2003 Jaguar S-Type
I changed the brakes on my 2001 f150 now it wont go into gear. is there a swith or something?
that is strange. check the fuse for the brake lights and look in the owners manual and see if there is a fuse for the shifter lock/ release
Jan 12, 2010 | 2005 Ford F-150
2007 Denali wont start
TRY TO UNPLUG THE BATTERY AND LEAVE IT OUT FOR 30 SECONDS AND PLUG IT BACK IN AND TRY TO START AGAIN. LET ME KNOW IF IT WORKS
Aug 11, 2009 | 2007 GMC Yukon
Husqvarna iz4817 change oil light needs to be reset
The oil change reminder will flash at 49 hrs for 2 hrs then reset itself. It will do this every 50 hrs.
Jun 30, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Wiring on a chamberlain 7200 opener
You'll need to go to : http://www.managemyhome.com/mmh/common/Home.action?sid=MMHMxSearsx00020
Go to the middle of the page 'Search Product Manuals'.
Type in your model #, xxx-xxxxxx of the garage door open.
It should give you the correct wiring diagram your looking for.
Feb 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
171 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
