SOURCE: Casio Exilim ex-z700 - lens wont open
Chances are you are not going to succeed. Water dissolves Coke but Kills cameras. Dropping them does the lens drive mechanism no good at all. Well now you are in a rock and a hard place. 1st thing to do is to go and buy the next camera. Then remove batteries and memory card from the existing camera and wet a tissue and wrap it around the lens barrel and let it stand face down for a couple of hours. Then find a poly bog. and in it put some salt or uncooked rice wrapped in a cloth[hanky?] Put hanky and camera in the bag close tight shut for a day. The idea is to draw out the moisture But I reckon you will need that new camera. As for a repair -forget it - these things don't get repaired
SOURCE: Casio EXILIM camera lens will not extend fully!!!
It's the focus lens gears. The often times get knocked out of alignment by an impact, or debris gets in there. This can be fixed, but Casio won't help. Hint...google my username. ;)
SOURCE: EX-V7 Casio Camera Stablizer Error
The problem is already fixed. I sent it to Casio Repair Office to get it fixed. They will repair for me without any charge and mail it back to me.
Thank you for the offer though.
Naweed Jan
SOURCE: casio Exilim EX-S770
Step 1: Take the camera firmly in hand and bang the bottom part against a hard surface. A desk works really well!
Step 2. Take off the right side molding and blow compressed air (A LOT) in the bottom of the camera.
If it doesn't work repeat step 1 and 2 again.
I had this problem and now it all works out!
SOURCE: Casio Exilim Z40 - Lens Error Message
You can try to "fix" this problem by holding down the shutter release button as soon as the camera power up.If this does not work you will need to replace the lens assembly. This should only be done by a qualified tech.
This is usually caused by one of two circumstances. (1) The user dropped the camera while the lens was extended causing a mechanical failure. (2) The lens attempts to extend while in a pouch or pocket without the user's knowledge. This usually happens when the user is carrying the camera with the battery in. When/if the REC button or power button is pressed accidentally, the lens will attempt to extend but can't. This causes the servo motors to "smoke".
