Pool & Spa Logo
ken bowles Posted on Jun 25, 2017
I have a Rheem pool heater model 2 66a the display is not working but the heater turns on and heats the pool. Nothing works on the display?
5 Related Answers
Mike Wenger
  • 14 Answers
  • Posted on Apr 05, 2009
SOURCE: Rheem water heater, will start but flame lasts 10 seconds
Is the vent fan working well and can you feel unobstructed air out the termination fitting outside?
John Morganti
  • 864 Answers
  • Posted on May 30, 2009
SOURCE: raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
Anonymous
  • 83 Answers
  • Posted on Jul 01, 2009
SOURCE: When Heater is turned on display shows 125, doesn't ignite/fire.
I am not sure if you have solved this issue, or not, but here is one idea. When you turn on the heater, it is reading the temp at 125/126 correct? IF this is what the heater is reading, then the problem is the Thermistor,or temp sensor, and is very easy to replace.
If you have an Owner's Manual, there are part numbers and instructions on how to replace the Thermistor. If you do not have one, follow the link below and it will take you to one online:
http://www.pentairpool.com/pdfs/MaxEThermOM.pdf
Anonymous
  • 244 Answers
  • Posted on Nov 01, 2009
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Anonymous
  • Posted on Jun 14, 2011
SOURCE: Solution for Jandy Lite 2 Pool Heater display flashes on & Off ..
Can a model LJ250P Propane 2005 model be installed indoors . The rating plate says it can. But manual says it cannot. What the hell????
My heater is displaying a sensor failure message
Year, model, and size of the heater.
What is the error message exactly?
Water switch open , heater heats up for short period and cuts out
ensure pump is running at full prime. clean the filter out as well. disconnect both connections from pressure switch in raypack heater. check continuity. if switch opens at any point and you have no flow restrictions then replace the pressure switch
Rheem pool heater there's no power to the display
ensure proper supply voltage to the heater....either 12 or 240 vac. display screen should get 24 vac.....if screen is supplied 24 vac then replace the display screen board.....if not getting 24 vac problem is occuring before display screen
Sep 13, 2013 • Pool & Spa
Rheem pool heater
The display can be decieving when the remote function is turned off it will be in all caps like REM OFF but when it is on it will look like REM oFF. In the on mode the "off" is actually reading the heater mode is off (not pool or spa).
1helpful
2answers
My Rheem model P-M266A-EN-C is displaying this: GVC. The heater isn't working. What does this mean?
GVC means Gas Valve Closed. This fault can be caused by many different problems, or even a faulty gas valve. Here is a link to a PDF file that give a step by step troubleshooting chart. This may help put you on top of the actual problem. http://shop.solardirect.com/pdf/pool-heaters/gas-pool-heaters/raypak-r-series-oim.pdf
Rheem is showingcode "REM" and
should ask, Do you have automation or external remote?
if no..take off remote setting by holding the three buttons down until display changes.
If yes.. this is an auxiliary remote so heater control is deactivated, look to the aux. However, This will control heater on/off and temp control but only heat as high as heater set point allows. i.e. Heater set to 82 degrees will only allow remote up to 82 degrees no matter what you set so take off REM by holding three buttons on heater, turn all the way up to 104 then put back on REM
1helpful
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Top Rheem Pool & Spa Experts
john h
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
