Model-88h-300-top element works no power to lower
Check again. Is there power to it but it's not working? If so, the bottom element is the one that always fails first because the sacrificial anode gets used up and deposits collect on the bottom creating a blanket of "insulation", making it not heat water and causing it to overheat (elements MUST be submerged, or they will burn up.) Chances are your element is bad. Replace, or if the water heater is more than 15 years old, get a whole new water heater. Good luck.
