SOURCE: unit leaking water,
if your humidity is excessively high unit wont be able to cope,try it again after hi humidity lowers
SOURCE: my water cooler runs but it doesnt cool anymore,
Hello. The sad reality these days is that a service call is generally going to cost you about $100. or more. You can purchase a new and much more efficient cooler at a box store for a very low price. AND, many bottled water companies give you a loaner cooler if you have them deliver the water to you.
SOURCE: Water leaking out of bottom of unit, near reset
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
p
SOURCE: The unit runs but no longer removes water from the
Edward, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air
temperature at floor level is colder than at shoulder level
in basement applications . Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If
none of the above solves the problem, it may be a case of the
compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are
5 years old or older.
Hope this helped you to troubleshoot and solve the problem without having to make any repairs or replacement of the unit.
