SOURCE: Reset anti flood device in dishwasher Beko DWD 4310 S
**** the water out of the pan below the dishwasher, there is a float in the pan if you have a leak and the pan fills with water
SOURCE: Need to know how to re-set the anti-flood device
I managed to clean the filter inside the dishwasher and drain a little residual water. I then re-plugged in the appliance and the anti-flood device seemed to reset and I have n't had any problems since.
SOURCE: Electrlux dishwasher - ESL 63010 - anti-flood
Got this tip from another board. Unplug and disconnect machine. Take machine out and tip 45 degrees to empty water in base of unit. Put everything back together. Thats it. Worked for me.
SOURCE: how can I reset an i30 (flood control) error?
you have to mopp up any water in the base of the machine. this can be caused by a leak . a sagging pressure pipe to the pressure switch can do it as well. you can tie it up to stop the sag. its at the front behind the plinth area.
