Question about Cell Phones
Shuts down randomly and says ERROR #
Bberry 8330
  • 105 Answers
Delete extra things from memory of phone
Posted on Jul 26, 2009
My laptop shuts down randomly
Tell them to give you a NEW computer. You got a lemon. They WILL give you a new one if you've had this much trouble with it. I'm serious, they do it all the time on lemons. Be assertive! They will cave.
Jun 29, 2012 | Dell Computers & Internet
My computer is shutting down on its own. Is this
Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
May 15, 2010 | Dell Dimension 3000 PC Desktop
My computer keeps shutting down randomly. Also when i try to use F10 it will not respond if i try and run error checking the system will crash/shut down or give me a black screen. Basicly it randomly...
Possibilities:
1. overheating, and automatic shutdown.
Check that the fans are working.
2. bad RAM, causing "random" crashing.
On a "good" computer, download the free 'MEMTEST86+' software, and run it, to test your RAM.
3. Leaking capacitors on motherboard, causing "voltage-spikes", leading to "random" errors.
4. Bad disk-drive. Remove the disk-drive.
Connect it as a "slave" drive in another computer,
and run 'CHKDSK' ("Check Disk") to look for problems.
Apr 16, 2010 | HP Pavilion a450n PC Desktop
Bberry tour got soaked how to retrieve txts
Sounds like you have a broken trackball button membrane. The only way to get it up and running again is to open your blackberry2_bing.gif to physically clean or replace the membrane. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is a Blackberry curve Repair Guide that shows how, the part is available on Ebay.
Feb 01, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
Error code on my blackberry 8330
Keep getting error code 0x80043ac9 when sync'ing my BB Curve 8330. Won't let me finish sync'ing address book. Stops at 2906 of 3814 contacts. Calendar won't update either. Worked fine until 8/10/10. Back up works fine.
Jul 06, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Placed password shut phone down
Which model are you wanting help with - You mention both the 8300 and 8900?
In any case - The 8300 doesn't have a reset button? On the 8900 it may be behind the battery cover if so you will need a paper clip.
The following advice is general to Blackberry's and will help clear the memory and reset issues - These are both the soft and hard reset.
You can do a soft reset using Left Alt, Right Shift and Delete - Hold down keys simultaneously for a couple of seconds.
If that doesn't work - Try power down, remove the battery for a minute or so, re-insert battery and then power back on.
Let me know how you get on with the above - If they don't work - Can you also clarify which model no as I have given you generic advice for both models...
Jun 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Need to unlock bberry
Call your service provider and tell them that you need to unlock your phone to use it overseas. It works like a charm. It the law that the phone can be unlocked to use with other service providers, but they try to delay you on it. this works and i recieved mines within 48 hrs. you will need your IMEI number that is posted inside the phone.
Apr 08, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
CUrve 8330 having trackball error
Hi
It seems that there might be something blocking it, like dust, press the trackball down and then try to scroll quickly towards the bottom, try it a couple of times, it should fix your problem
David
CellUnlock.net
Feb 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Random shut down
The PSU voltages can be checked with a digital multimeter at the ATX connector, 3.3v (orange), 5.0v (red) & 12v (yellow) if the DMM is indicating values of MORE than 5% variation your PSU is the likely villain (best to rule it out first).
Are you getting a BSOD (Blue Screen Of Death) or error messages when you PC randomly shuts down?
Jan 23, 2009 | Nexus Prolong:Extra Cooling after PC shut...
what you need to do now is take the phone to a mobile service center and have the mainboard fix or flashed....jun error means that the unit is going bad.
money_kohil - after the passowrd was enter incorrectly 10x then take the will blank and reset to its default and clear al saved data.....if it s not powering up after that then you will need to take the phone to a mobile service center.
Dec 27, 2008 | RIM BlackBerry? Curve 8330 Cellular Phone
Cell Phones Logo
46 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
