Computers & Internet Logo
J
Joselito Damian Posted on Jun 24, 2017
It doesn't boot up. It can be turned on but it won't boot up. After 3 - 5 minutes, it is turning off even though it has a full battery charge. How do you fix this kind of problem?
5 Related Answers
A
Anonymous
  • Posted on Dec 26, 2007
SOURCE: Samsung SGH-T219 Turns off even though it says fully charged.
my phone is 1 week old and it does the same thing
Anonymous
  • Posted on Jun 07, 2008
SOURCE: Dead Garmin
I had the same problem - worked great for a year and yesterday was totally dead - not a hint of powering up.
I pulled the blue front "frame" off and held the reset button for about 5 seconds. It powered back up and works like a champ!
-Johnnyx
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Jan 01, 2009
SOURCE: Sansa Clip not holding charge
Locking the player will not allow the player to charge properly, no matter how long you have it plugged in.
Anonymous
  • Posted on Apr 05, 2010
SOURCE: LG Renoir Battery issues
My renoir has just developed this issue.
I have tried 2 batteries, tried re-flashing the firmware (even tried a custom firmware) and nothing.
I am buying another battery to see if i were unlucky with the battery I bought.
This does not appear to be an uncommon issue as I have found several threads online regarding this. No definitive answer as yet.
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on May 15, 2011
SOURCE: The starter won't completely turn over even though
Sometimes on the Briggs and Kohler engines, the compression release fails to operate at the proper time or is malfunctioning. A remedy for this is to remove the valve cover(s) and adjust the OH valves per the manufacturers specifications. This enables much easier starting, produces less wear and tear on the starter and may allow your new battery to completely turn that engine over. Out of adjustment valves mimic a weak or failing battery quite well and the engine hangs up on the compression stroke because the compression release system is not working properly. Adjust those darn valves.
My w1 cherry mobile doesn't turned on even the battery is full
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 12, 2012 • Cell Phones
Computer just shuts off when i unplug even though shows full battery
POWER SUPPLY & BATTERY PROBLEM
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Even with battery charged, sometimes the machine won't turn on when unplugged
It sounds as though you have a defective battery. You will have to go through Macintosh for assistance.
Acer aspire laptop suddenly shut off and cannot turn back on
try it without the battery on the laptop. if it boots and stays on, put the battery back on and see what happens. If the problem persists, replace the battery. Acer will replace it free if you are still in warranty
2answers
RCA S2001A mp3 PLAYER
yeah i have the some problem. PLEASE HELP ME
2answers
Startup/charge issue
hi.. unfortunately i've seen many cases like this and it looks as if from what you are describing that your laptop is fried if there is no boot up at all.. how old is you laptop and what brand is it?
Grand Canyon Tech
Grand Canyon Tech
