Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
SOURCE: My TV GOLDSTAR,i can hear the sound but picture is lost
The set defective the Hi-Volt Transfromer and the Horizontal output
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
SOURCE: no picture on flat panel tv. has sound
Sounds like the digital control board, 6871qch038a Lg Digital Control Module subs to 6871qch038c. But that's just a first something I would check in this unit. Replace also capacitor C19, 630V big blue square cap very common failure for no video. You might want to shop this one thee are a host of problems with this unit that would certainly get some needed attention if a qualified tech were testing it and looked up the bulletins.
Good Luck!
William Rayburn, CET
Premium Technologies
SOURCE: TV abruptly lost picture still has sound,less than
change your scart lead or even just make sure its connected propperly have a look at the pins in the scart and make sure none are bent or missing
SOURCE: My plasma tv has just lost it's picture. I do have
There will be a fault in either the Y or Z sustain boards, these are responsible for driving the screen 9hence sound but no picture). The popping sound willhave either been a fuse blowing on the board or another possibility is one of the drive ICs on the buffer board has blown. If so it's best to replace the board.
