SOURCE: 2005 ford f150 reverse is slipping
Time for a clutch if it has a standard transmittion, or maybe fluid change and band adjustment if it's an automatic.
SOURCE: I have a 2001 chevy silverado pick-up, regular
Here is a link to specs for that year model of truck, I would need more info such as auto/manual, and 4x4 or not. Anyway it's an easy chart to read. But technically speaking a 1/2 ton pickup is only rated to carry 1,000 lbs in the bed. I wouldn't personally suggest doing more than that, if you overload the bed you can have trouble steering and stopping. I hope this Helps please rate this thank you
SOURCE: some times my 1984 ford f150 idels fine when its i...
In general, yes. This is a carb tuning issue. Another possibility is a vacuum leak somewhere, but most likely, it's a carb issue. You'll typically see your rpm drop a bit when you put it in gear, but that it sometimes stalls out points to a carb issue.
SOURCE: how often should brake fluid
It should be changed every time you do a brake job. 20 to 30,000 miles
